Net-Bed / hammock style / Mattress alternative?
Hi Everyone,
I saw this bed on a blog and it keeps coming back to me.
Unfortunately I don't know anything about it, who made it, and how.
I did some research (didn't find the source) but learned that many people consider sleeping on a hammock very comfortable.
So maybe this could be used as a real bed?
This is a burning question because I'll might have to buy a new mattress at the and of the month but I feel like DIY :)
So, any ideas on how to build such a thing, or on how usable it is?
Or maybe you are the guy in the picture? ;)
Thanks,
elbotho
Thanks,
elbotho
Maker Faire 2013 Slide Show!
Fried Contest Launches 5/13, HQ Celebrates with Fried Day Friday
MEH! :D A Build Night at Montana Ethical Hackerspace!
Got contest ideas? Want to help HQ staff?
Large Instructables Robot head made out of driftwood, check it out!
Call for pre-made parts!
The Instructables Green Design Contest is starting on Earth Day!
My instructable made it into Popular Science!
Orbotix wants to see your hacks - you could win a Sphero!
Transformational experience for Instructables Artist-in-Residence
Visit Our Store »
Go Pro Today »
2. Do you have a fear of heights and trust your skills in anchoring the net suspended about 8-feet up?
3. The trampoline looks like it is stretched pretty taut, it may not be comfortable depending on the size of the "mesh" or spacings of the grid.
4. You would have to determine the safety or load bearing capacity of your cargo net.
5. Weave nylon webbing like a lawn chair instead of using rope or paracord or mix it up for a cool design.
6. People sleep in all kinds of hammocks every day. Make it and test it out. If bad, throw a matress pad, sleeping bag, blankets, bamboo reed pad or futon over it.
Good luck.
I wouldn't build the exact same thing. I'd make a kind of platform bed, not so high above the ground and mine would be smaller (don't have the space).
The pillow part is good though :) and if its cold or to hard a duvet over the net might do the trick.
Ok, so you'd "weave" it yourself? Any instructables on that?
It looks so very regular in the picture...
There are a couple of relevant instructables:
http://www.instructables.com/id/Sellf-Adjusting-Hammock/
http://www.instructables.com/id/Instant-Hammock/ (steps 5-9)
The net came from netting.com in 2008. Their website isn't great, I found it
easier to deal with them via email. Initial response from them:
"It sounds like you intend to build a hammock? On our website
www.netting.com, you can view several options. I would recommend
either 30K or 35K netting. Both are knotless construction made from
High Tenacity Polypropylene. The model 30K has a 2" hole size, the 35K
has a 2.5" hole size. Either netting is priced at $1.50 per square
foot without a finished border. A rope border would cost approximately
$2.00 per linear foot."
We decided to go with smaller hole size (30K) -- incidentally, just
the right size to hold a beer bottle. Some more details on this one:
"The model 30K netting can hold a dead load of 2,000lbs. You can
install the netting without a finished border. We do sell our netting
in any size; however a minimum order is $100. Shipping is UPS ground
and varies by weight and distance. Currently, we have model 30K in
white, black, tan and light grey."
We got two pieces; one 36" x 228" for the hallway, and the 102" x 144"
one for the big net, in the diamond pattern. These were actual
dimensions of the spaces we wanted to fill; the netting ended up
stretching quite a bit, so we could have probably gone with about 80%
these dimensions. Total price was about $250 shipped.
Anchoring is a bit tricky, since the forces on the wall anchors can be quite large (see how the board is pulling out in the back right corner in the picture). We used a large number of medium-duty eyehooks (each rated for about 100 pounds), and two ropes through the eyehooks and net to mount fairly securely and safely. We've had about 8 people on there, and no deaths yet (we added the second rope and attached the board more securely later).
Let me know if you have any ?s ...
Cheers, Jason
When I have some more space I'll build one.
It could be nice to have something like this outside.
Maybe you could consider hanging a Mayan (mesh) or Brazilian (fabric) hammock instead. Mayan and Brazilian hammocks don't have those very unstable spreader bars like you see on typical rope hammocks, so you won't tip out, and they're VERY comfortable to sleep and lounge (and "play") in. You lie ACROSS them, so you can get a good flat sleeping surface, but it's highly flexible and conforms to your body as you move, so it minimizes pressure points, and the gentle rocking motion is really relaxing. (Ask any baby!) This is what I sleep in almost all the time now, and it has done wonders to relieve my back and neck pain from long-ago injuries. Hang it loose and lie across it, and then you won't get that "banana" curve in your spine. If you're interested, Google "Mayan hammock" They're not expensive and will last a long time with reasonable care. Some folks sleep all the time in a nylon camping hamock, but I find a Mayan or a Brazilian to be MUCH more comfortable and spacious when I'm at home. You'll get extra points for its intriguing & inviting appearance, too!
If you want something that has a flat, firm mesh sleeping surface, what you probably want is a charpoy, as you already commented. Google shows some pix of some really nice charpoys. I made one a few years ago (gave it to a friend, so I no longer have it) and slept on it every night. I made the frame from hardwood poles and 4x4 post legs, and I wove a close mesh with cotton cord instead of the traditional (and itchy) jute. There are several issues with a charpoy, but I really loved mine and plan to make another. If I do, I'll post an Instructable. One thing you need to know is that a charpoy only works well for small beds (no wider than a twin bed) because (1) it's hard to keep the side rails from warping inward due to the constant tension from the cords, plus your body weight, and (2) the mesh will stretch, no matter what you use, and start to sag in the middle. That's OK if you have a way to tighten it up, but it's not easy. Finally, it's not comfortable sleeping directly on mesh unless it's very closely woven, so you'd probably want a pad on it. I used a cheap Kmart air mattress on my charpoy, with a fitted pad & sheet on the air mattress to keep my cats from popping it with their dagger claws. It was very comfy, and not hot in summer like an ordinary mattress. In winter I just added a wool blanket under the mattress pad. I'm thinking about making a double or queen-size charpoy that won't bow in across the middle, but the air mattress was key to distributing my weight to keep the mesh from stretching and sagging on my old twin-size one.
Another possibility might be a trampoline, but to buy one big enough would be very expensive. Maybe you could find a used one, or make it. The replacement tramp mesh and springs can be purchased online if you decide to go this way. The springs and strong tight mesh would give you a flat, firm, no-sag surface. And you could have quite a lot of fun on a trampoline bed!
If you really want to sleep suspended, please don't try it over a stairwell or loft as in the photo! Lose your mattress, yes, but not your life!
Thank you for sharing your experiences. Now I'd like to try all those options.
Great how this thread turned out to be such a rich collection of ideas!
1. Go to google
2. Type in "hamacasutra"
3. Be amazed
Thanks for the great ideas!
It's a pretty simple frame on four posts and some sting woven around that.
A quite similar concept, still it's rather hard for a "western" taste in comfort I guess.
But the idea of not having a mattress is still thrilling.
