New computer freezing problem
So I just built myself a new computer with the following specs gigabyte motherboard model: GA-MA770T-UD3P (rev. 1.0) phenom 2 tri core processor 4gb ddr3 mushkin ram radeon 4670 tp link wireless card 2 LCD's hooked up to the 4670 Windows 7 64-bit/ XP 64-bit (not at the same time) +tons of cooling so nothing is over heating I installed windows 7 and it kept freezing up every once in a while and I tried just about everything to fix it. Updating bios, cleaning the registry, making sure all the drivers are up to date, all sorts of things. So I thought it was Windows 7 giving me the problem. I uninstall windows 7 and installed windows xp. I loaded up everything got the drivers up to date and after a couple of hours it froze up. Then I rebooted and bam another freeze 3 minutes into being on the computer. And again the next time 15 minutes into being on the computer. Now Im not sure if the freezing is happening on windows 7 for the same reason as on Windows xp and it is driving me crazy not being able to use my new computer Any ideas on what I can do to fix the problem? Thanks for any help. Got some more details. 1) I noticed when I move a window around I my cp usage spikes from 1% to close to 30%. Not sure if this is normal but with tri core 2.8ghz doesnt seem like this is good. 2) When I have 3+ windows open and I drag them over each other it leaves a trail or shadow of its edge so it looks like I am dragging many windows. Sometimes this shadow is just white. 3) Also when I try to install a game the computer will always freeze before it finishes and most of the time right at the beginning. 4) When I press the button to force it to go off and then turn it back on it often just comes up with a black screen and I have to repeat. it always turns on the second time. How can I tell if it is my hardware? Just did a video stress test and benchmark. Everything was normal. Ran "cpu stability test 6.0". Watched it for 20 minutes then I left the computer and came back to see it frozen in screen saver. Speedfan temps- Temp 1- 26c temp2- 25c HD0- 26C core- 15c It is pretty cold in my room. I also found something that makes it freeze every single time I have done it so far. When trying to install world of warcraft as soon as I click agree in the install setup it freezes. 6 out of 6 times. My power supply is 500w "stable power"
Tanners (author) 8 years ago
thanks guys for the help i swapped the ram with some other ram i got off woot.com and all freezing stopped so i sent he other ram in to newegg.com for replacement who would have thought ram could couse so many problems but still pass all tests i ran
caitlinsdad8 years ago
Reseat the RAM and hardware cards. Try to run the system with just a single display and see if you get the same problems. You can also try to run the system with a single memory chip to see if your RAM might be flakey. Swap out the RAM or build up to see what is stable. Good luck.
lemonie8 years ago
Did you know that Gigabyte make the development boards for Intel? All new Intel boards are derived from a Gigabyte development model.
Hmm, have you checked the CPU is cool? Badly-mounted can cause you a problem regardless of what cooler you've got strapped to it. Normal BIOS settings?
(I'll think...)
L
