loading
Ohm's law?
so, i have a broken soldering iron, and i want to fix it
can someone =smart= calculate the required resistance of wire at 120v ac
i don't care about the amperage, as long as its under 2 amps
please give me a range of resistance, i don't like to trip fuses, (my parents hate that!)
Picture of Ohm's law?
1-10 of 18Next »
I had a 40W Weller burn out on me once. It overheated.
It was glowing from the heat...
Sandisk1duo (author)  gimmelotsarobots9 years ago
i left my iron on for a couple hours (not before it broke) the tip was glowing slightly red, very, very dimly the little grip was getting painfully hot, so i insulated it with double sided (sticky) foam, and electrical tape
Big Bwana9 years ago
60 Ohms is 2 amps but that is 240 watts. more then most soldering irons, unless your soldering pipes... Most small irons are in there 25 to 40 watt area 576 to 360 Ohm area....
Sandisk1duo (author)  Big Bwana9 years ago
thanx!
. Keep in mind that the impedance will be higher than the resistance. How you wind your coil will determine how much difference. Even 360 ohms resistance _may_ turn out to be too much impedance. May not make enough difference to matter. . And make sure you use the right type of wire/insulation for the high temps you'll generate.
Sandisk1duo (author)  NachoMahma9 years ago
impendence? i'm not familiar with that term, i though impendance was/is resistance
Sandisk1duo (author)  Goodhart9 years ago
thanks!
What type of iron are you fixing ???
40 watt weller
1-10 of 18Next »
