loading
Old JVC Boom Box (Antique?)
Hey guys, upon my travels the other day, I stumbled upon an electornics bin or two and one of them happened to have a few "ghetto blasters" or boom boxes as other people would call em. I should really get some better pictures, but these will have to do.
I brought it home expecting it NOT to work at all, as usual. It DOES work but in a somewhat limited way. I brought it home upon the conclusion that it felt rather solidly build for such a small system and it looked the nicest out of all of them.
The "Problems" sort of speak:
* Well for one, the left channel doesn't work, but BOTH the speakers DO work. They both have battery compartments (6 C cells each speaker in series = 9v-ish?) and they both have "extension" cables so you can unhook the speakers and place them elsewhere, the wires are 4 strand ribbon cables and the power is also transported down these wires. I find it rather retarded, because at full length, these wires are a foot long at best?! I managed to get around this debacle for now and plugged the extension wire of the left speaker, into the plug for the right speaker, powering both speakers off one channel. This works half decent, but it doesn't go as loud as one speaker would go, and it gets distorted easier at high volumes.
* The tape deck doesn't work. I hit the play button and it DOES indeed make a whirring sound, so my guess is that it needs a new rubber belt for the motor, and I have no idea where to get something that small. Did I mention that apparently the tape deck, actually comes OUT of the stereo, and theres a compartment for a set of AA batteries, thus turning it into a shiny silver 80's walkman. I'm ultimately dumfounded..
* The switches on the top of the unit, primarily the two buttons that change the "fuction" or input of the boom box, are crapping out really bad, like if I set it to radio, I have to raise one switch, and push one down, but it sometimes doesn't work, or it crackles really bad, or isn't as LOUD as it should be, but if I jiggle the switches enough, I can usually coax it into working. It's annoying at best. They are really impossible to get at and they're long pushbutton switches with a long plastic rod that pushes the switch on the board. I really doubt I can get these switches open and adjust/clean them. Should I maybe get the dremel out and but some little toggle switches?
* It's missing the little faceplate for the radio selector? Oh well I can still manually tune in a radio station without knowing the number, primarily 94.5 the bull here, it's pretty hard not to miss it blaring some rock or heavy metal.
I like this little unit and I wanna fix it up/tweak the crap out of it. If I could get subwoofers small enough, I would upgrade the speakers, reinforce the inside of the speaker casings with epoxy, and maybe dremel some bass ports (would that be a good idea? From what I can tell, it's a totally sealed unit, but it would probably benefit from some "bass ports").
Also, would it be beneficial to "reflow" the amp board? Like theres a board with a transformer and what appears to be a stereo transistor, but like a wide one for two channels, instead of two independant transistors for each channel. So I can only imagine if one side of the chip is working, the other side should too. Would it be a waste of time to reflow all the solder joints or no?
Picture of Old JVC Boom Box (Antique?)
lemonie6 years ago
Nice find, (but not that old).
L
There's one of these in tech, a slightly newer one that some old woman gave one of the tutors, it's fully functional and just as confusing to look at and understand...
Punkguyta (author) 7 years ago
 OMG why did it take a WHOLE day for my topic to show up?!?
 1.www.instructables.com/community/Why-it-takes-so-long-for-an-instructable-to-publis/
2. Gut it out, hot glue in an ipod to make it an ipod blaster.
Punkguyta (author)  caitlinsdad6 years ago
 Lol, I like your drawing.
2. I don't exactly want to gut it out.... maybe if I had some really nice portable/powerful amp that could fit into it with maybe say, 50 watts of power per channel, and still be able to use some of the original controls....?
It would seem like a shame to rip it apart for something silly like an mp3 player or ipod. Did you not see it has RCA jacks on the back of it?? I've been using an mp3 player with it and it does work!
