Overpriced Stuff: Electric Motor Speed Controllers
That page has a controller capable of 144v at 550a peak (about 90 horsepower peak) for $1250. I just designed a speed controller with parts off of digikey.com for about $200 that could handle 144v at 690a continuous so it could probably get over 180 horsepower peak.
All things considered, their's costs over 10 times as much per amount of power.
This seems like a BIG markup. I can understand shipping costs, labor costs, etcetera, but something seems a little messed up here.
NOTE
I am not sure that the design is quite right, and haven't done it myself, so criticism is good.
32
comments
Add Comment
I'm not sure at all wether the idea would work. I just figured that an inverter already change 12 volt DC to 230 volts AC (or 110 volts) at up to 3 kilowatts. An ACmotor, such as a vacuumcleaner, uses those 50hz to alternate and rotate, instead of with a mechanical commutator. If I'm right this is done with an oscillator somewhere at a low voltage, exchange/modify that for a squarewave oscillator that can be controlled and you would have a PWM curcit that drives an AC-motor at a controlled RPM from 12v batteries with 90% efficiency in the transfer without making changes to the motor.
As I've said it's just an idea, I could be wrong for any number of reasons and I'm probably never going to try it out.
Whenever I need to use formulas I reluctantly look them up, put'em into Calc (excel on MS) or some other mathprogram. I then take the answer I get, tweak the formulas and values until I get an answer that aprox equals my measured values.
Frankly I've been frustrated with Ohm's since childhood and it's mostly because it's only an approximation and the materials we use are only precise down to 1-5%, after that it's all quantum.
I think I got most of the stuff on there, and a lot of the parts aren't critical as to which one you use, but the really big MOSFET is here. There are some others on there that are almost as powerful and that you don't have to order two of, and those should work fine too. If you have any questions, just ask. I'll get back to you with programming for the microcontroller (for a picaxe 08M).
You didn't mention power dissipation. Max current and max power dissipation are two separate issues in power semiconductors. You can only sustain the max current IF you manage to dissipate enough power that the junction(s) temperature stays "reasonable." With Rds-on of 1.8 mOhm and, say, 600A flowing through the MOSFET, I calculate that you need to dissipate about 650W, which is no small feat. Does your current cost estimate include a big heatsink and fan?
The circuit you show has no provision for turning the MOSFET off; you'll charge up the gate to Von (maybe) through your secondary mosfet, but there's no discharge path to a Voff when it's time to stop. A fair amount of attention in high-power mosfet circuits goes to making sure that the turn-on and turn-off events happen FAST, because in-between the MOSFET is going to be operating in a linear region where Rds is much higher, and the power dissipation will leap-up (linearly with Rds-on) in neat little spikes, and fry your MOSFET if you aren't careful.
And of course, at 600A, your interconnections and even your wire become things that you have to pay pretty careful attention to.
In short, a speed controller at this sort of power level is one of those things that SOUNDS easy ("just use a huge MOSFET"), but quickly gets more complicated as you have to take into account all the annoying real-world behaviors that exist.
There are some "starting points" in the "DIY electronics" portions of RC Forums, though of course most of those are for far lower currents than you'd encounter in a full-sized car.
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
