loading
PCI Device Tutorial
I can't seem to find any tutorials for creating a PCI card.
I was thinking of something like a simpler version of this.
Anyone here made an PCI devices? Or any links?
Thanks.
1-10 of 15Next »
Punkguyta8 years ago
Use your parallel port?
alexgeek (author)  Punkguyta8 years ago
That's defying the point of using an internal PCI port really.
Well really, parallel provides the same TTL functions as that card. So really I wouldn't bother wasting the extra pci slot and my money if I already had the port to do what I needed. And from what I can see the parallel port can be used for LOTS of things.
Oh yeah, forgot to say.
Due to a recent capacitor explosion.. my parallel port is no more.
Had to buy a new board, only has a serial.
Guess that will have to do.
That is.. if vista would even pick up on the fact that I have a serial port.
Strangely it says I have an LPT1 printer port.. that's parallel right? Which I don't have.
Strange, I didn't think it would be that hard, in principle I thought it would be like parallel with a different connector.
Perhaps it would be worth a look to see if you motherboard has pin headers for a parallel port, I just pulled apart an old tower the other day and everything was plugged into the motherboard with ribbon cables, even the onboard vga port.
Aye, was just reading up on the ol' manual and I do have have the headers for a parallel port inside. Don't really want to be running my computer with a new motherboard with the case off and me jamming wires all over the place quite yet though. Just gotta wait for some capacitor samples and I should be able to fix my old board and build a test pc for this sort of stuff. Still, not sure why its not picking up on my serial port, I'll have to fiddle with my BIOS again.
You don't have to "start jamming wires in there". Just find an older computer tower with the parallel port attached via a ribbon cable. The end will be fitted with the right length of pin holes to accept the header on your motherboard. I can't see it being some kind of propriety cable.
alexgeek (author)  alexgeek8 years ago
That was easy, for some reason it was disabled in BIOS. Now I've gotta test my max3232.
Sandisk1duo8 years ago
you can't create your own PCI card.... it's almost impossible
alexgeek (author)  Sandisk1duo8 years ago
As far as I'm aware its like any other way of connecting a device to your computer but it requires you make your own driver.
1-10 of 15Next »
