3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
POWERING ATOMIC REACTOR CLOCKS:LASER SOLAR PANELS:USE LASER LIGHT NOT SUN
USING LASER SOLAR PANELS(NOT SUN LIGHT LASER LIGHT) INSIDE ATOMIC REACTOR COULD MAKE REACTOR FIRE SAFETY WITH USING FIBER OPTICS THAT HOLD LIGHT ENERGY TO TRANSFER ENERGY IN AND OUT OF ANY ATOMIC CLOCK: FIBER OPTICS CAN MOVE LIGHT THROUGH ANY BEND OR SMALL TO REACH PLACES AND THEN TRANSFER ITS LIGHT TO ENERGY WITH THE FOLLOWING IDEA. BY SHINING LASERS ON SOLAR PANELS THAT ARE INSIDE ATOMIC AREA DEVICES TO GIVE THE PANELS ELECTRICITY FOR REACTOR CLOCK AND REPLACING ALL DANGEROUS WIRES THAT SEND ELECTRICITY TO ATOMIC PARTS OF NUCLEAR PLANT. WITH NEW FIBEROPTIC WIRES TO SEND PHOTOVOLTAIC WIRES THAT SEND ELECTRICITY WITH LASER LIGHT. VERY SAFE COMPARED TO WIRES THAT WHEN CUT MAKE SPARKS OR FIRE. FIBEROPTIC WIRES ARE SAFE IF CUT ONLY NON DANGEROUS LIGHT WILL BE LOST. AND COULD REDUCE RADIATION FROM CROSSTALK THAT COME FROM REGULAR COPPER WIRES. One more idea can you charge a solar panel battery recharger by shinning laser beam on the solar panel cells in places were there is no sun light using laser light which can charge a device from a range of up to a football field if needed. This might be used in caves or evenin drilling for in off shore oil rigs were there really is no light in deeper water. And all other light sources of light would be distortedby reflection from the water. Only a laser beam could recharge aelectronic device by using photovoltaic in deep water where sundon't shine and only a laser will not have all of its light reflectedbecause of the water's reflection property, you would only be able touse laser light properties has less water reflection than normal light. BY HUME SCIENCE INTERNSHIP FIBER OPTICS TO SEND LIGHT INSIDE ANY TYPE OF ATOMIC AREA AND CONVERT IT ONCE INSIDE CORE INTO ELECTRIC POWER AND SAFELY DECREASING RADIATION PROBLEMS. THIS IS GOOD BECAUSE LESS COPPER WIRES ARE NEEDED.(ONLY LIGHT WOULD BE TRANSFERED IN CASE OF WIRE IS CUT ONLY LIGHT WILL ESCAPE MUCH LESS DANGER. USING FIBER OPTICS TO SEND LIGHT ENERGY ONTO SOLAR CELLS INSIDE REACTOR/THIS IS A GOOD SAFETY TOOL BECAUSE IF FIBER OPTICS ARE CUT ONLY LIGHT WILL BE EXPOSED AND NOT DANGEROUS ELECTRICITY WHICH WILL CAUSE RADIATION PROBLEMS. TO SEND ELECTRICITY INSIDE THROUGH OUT REACTOR//: INSIDE ATOMIC RADIATION AREAS. THERE ARE NO NEED FOR ELECTRIC WIRES. IF ELECTRICITY IS MADE INSIDE REACTOR CORE, BY SHINING INFARED ON SOLAR CELLS OBJECT NOT SUN LIGHT ONLY INFARED LIGHT ON THEM PANELS. THIS LIGHT HAS TO BE LASER OR INFARED BECAUSE IT CAN BE CONTROLLED USING INFARED LIGHT THIS ALLOWS IT TO BE MORE CENTERED THAN SUN LIGHT CAN. REDUCING ATOMIC RADIATION IN ATOMIC REACTOR CLOCKS. AND NOT USING WIRES. A ATOMIC REACTORS CORE CLOCK HAS TO GET ELECTRICITY. THIS CAN BE DONE WITH SOLAR PANEL CELLS PLACED AND CONNECTED TO THE CORE'S CLOCK. THEN BY SHINING LASER LIGHT OR INFARED LIGHT ON SOLAR PANELS THAT ARE INSIDE THE CORE CAN GIVE AND GET THE LIGHT ENERGY POWER IT NEEDS TO RUN TRANSISTERS AND COMPUTER CHIPS. FROM SOLAR PANELS THAT ARE CONNECTED TO THE CLOCK INSIDE THE CORE. AND ARE BEING GENERATED BY CONTROLLED LASERS THAT ARE ALLOWED TO BE AT VARIABLE DISTANCES. CAN ELECTRICAL ENERGY BE TRANSPORTED BY A LASER. SURE JUST SHINE IT ON THE SOLAR PANEL AT NIGHT AND YOU WILL GET A LITTLE ENERGY, SURE IT WORKS. CAN A ATOMIC REACTOR GET ITS ENERGY VIA LASER LIGHT INSTEAD OF WIRES DOING THE TRICK. NOW WITH LASER OR FIBER OPTICS. WIRELESS ELECTRICITY CAN BE SENT WITHOUT WIRES.ELECTRICAL WIRES COULD BE THE PRODUCER OF STATIC RADIATION. WIRES DO SEND ENERGY INSIDE THE CORE AND GIVES ENERGY FOR THE CORE'S REACTOR. CAN THIS IS ALL DONE WITH NO WIRES INSIDE THE CORE; IF WE ALLOW ENERGY TO BE SENT VIA LASER LIGHT TO A CONVERTER OF SOLAR PANELS COULD CREATE ELECTRICITY IF THOSE SOLAR PANELS WERE DIRECTLY SHINED ON TO BY LASERS. A GREAT DEAL OF WIRES COULD NOT BE NEEDED. SENDING POWER TO CORES WATCH OR CIRCUITS IS POSSIBLE. BY SHINING A CONTROLLED LASER ON THE INSIDE OF A CORE'S SOLAR PANEL CAN BE ACHIEVED BY FEEDING THE SOLAR CELLS INSIDE THE REACTOR WITH LASER PHOTO ENERGY LASERS WOULD SIMPLY SHINE ON INTERIOR REACTOR SOLAR CELL COMPONENTS. ONLY DIFFERENCE IS INSTEAD OF SUN LIGHT CREATING THE ENERGY IT WILL BE A HIGH POWERED LASER SHINING ON THE PANEL SOLAR CELLS. USE LASER LIGHT WHICH IS MORE DIRECT AND IS MORE FOCUSED OVER A LONG DISTANCE. LESS RADIATION AND LESS WIRE WASTE IS THE FINAL RESULT. HAVE A GOOD CLEAN DAY. THIS IS A NEW FORM OF TRANSFERING ELECTRICITY TO EXTERNAL LOCATION. USING FIBER OPTIC LIGHT AND SENDING IT AND THEN RECIEVING IT ACROSS A DISTANCE WITHOUT WIRES. THIS SEEMS SAFER TO ME BY USING THIS METHOD. REMEMBER THIS; WE ARE NOT USING SUN LIGHT IN ANY OF THESE METHODS ONLY LASERS OR FIBER OPTICS. THIS IS INFORMATION FROM A SCHOOL PROJECT OF MINE AND IF YOU CAN GIVE MORE ON THIS SUBJECT PLEASE DO. PLACING SOLAR PANELS INSIDE BUILDINGS NOT JUST OUTSIDE, AND CAPTURING OFFICE LIGHT 24 HRS MORE PROJECTS THAT I WOULD LIKE TO EXPERIMENT A INTERNSHIP WITH! PLACING SOLAR PANELS INSIDE BUILDINGS NOT JUST OUTSIDE, AND CAPTURING OFFICE LIGHT 24 HRS
6 comments
May 16, 2012. 4:25 PMcaitlinsdad says:
First, use lasers to fix that Caps Lock key.
May 16, 2012. 4:50 PMGoodhart says:
Could you make any sense out of all that? Or was it more like: this is just TOO hard to read.....forget about it....?
May 16, 2012. 5:18 PMcaitlinsdad says:
Homer Simpson working on his postdoctorate thesis at the nuclear plant on the third shift?
May 16, 2012. 11:18 PMGoodhart says:
The lack of punctuation makes it harder to read than ancient Hebrew (where they didn't have punctuation NOR vowles; but they did have sentence structure).
May 17, 2012. 4:14 PMGoodhart says:
they didn't have vowels either :-D
Jun 22, 2010. 8:45 PMDestructableman says:
Can you show an instructable for this?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
