PVC Pressure Canister
I want to build PVC Pressure Canisters what diameter pipe should I use?
Naysayer's welcome to comment I would love to here the crazy and logical reasons this would not work
Pfarmkid
1-10 of 16Next »
look for the post by maewarts, where he talks about nearly killing himself with pressurised PVC
Pfarmkid (author)  steveastrouk4 years ago
Please give me a link i could not find it
look for arduino controlled pneumatic cannon.His handle is Maewerts.
He nearly took his head off. ....
Thanks for the Thought I may stick with somewhere around 40-50PSI
I can't find anyone with that handle, are you sure it's spelled like that?
Moem Moem4 years ago
I'm assuming you meant the comment at the bottom on this page? https://www.instructables.com/id/Android-Controlled-Pneumatic-Cannon-Powered-By-Ard/
Pfarmkid (author) 4 years ago
Who thinks this won't blow up in my face?
Kiteman4 years ago
Define "pressure", define "PVC".
Different grades of PVC will hold different amounts of pressure.
What pressures do you want to store, and what volumes of those pressures do you want to store?
How long do you want to store it? How often (and how rapidly) do you want to cycle between high and low pressure?
Pfarmkid (author)  Kiteman4 years ago
Hey, Kiteman I was hoping you would see this. I want to store 100PSI for anywhere from 1 hour to a day in a tube i would like to put on a quick attach connection for the removal of the air. PVC as in Poly-Vinyl Chloride I believe. and pressure as in 100 PSI
You'll need to check, but I believe you need "schedule 40" pipe.
1-10 of 16Next »
