PVC vs Hydroponics and Rain water collection - a timely warning
I've been interested in hydroponics for a very long time. Now the time has come around that I should get out and get some form of it built and begin using it. I began researching different styles and of course reading here on Instructables.
I read about all the different styles and methods. I looked at kits, partial kits, and building my own design.
I also began to think about moving away from the use of the well on my property. I looked into rain water capture. Here in the north east there's been no shortage of rain even in a "dry" year.
In nearly every tutorial or kit I've found them based on a PVC product or using PVC materials. I remembered that there had been an issue with Lead (Pb) being in PVC.
I looked it up. It appears that there are serious issues with the use of PVC and Lead is only one of them.
Here is a sampling of the links to the issue of Lead in PVC -
http://lists.essential.org/1996/dioxin-l/msg00205.html
http://healthychild.org/blog/comments/safe_pipes_mean_safe_water/
http://www.sciencedaily.com/releases/2008/06/080602091241.htm
http://archive.greenpeace.org/toxics/reports/whatswrong.pdf
This is just a few links - there are a ton more.
It's an interesting read and should give everyone working with PVC cause for pause. For example instead of using the PVC gutters I had planned on for the rainwater collection I've been thinking about making them from wood (Plywood) and coating the inside with Food Grade Shellac. I will be using PVC pots for container vegetable gardening this year but I will rough up the interior of the container (taking precautions - respirator, gloves etc) and again using Food Grade Shellac to prevent the PVC coming into contact with the growth media or growing vegetables.
I was sort of surprised by this info and just thought I should share it just in case someone was unaware of the issue. I would like to cross post this but am not likely to do so for concern of running afoul of some rule. Feel free to share this info though. In fact please share this widely-
Good luck with your projects,
Marcintosh
4
comments
Add Comment
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
