Paper crossbow Ideas
I need Ideas for paper crossbows.Not as complexed as seen on Myth busters, but something nice. Please respond!! I Have Ideas for the barrel- a rolled up piece of paper but the rest isn't creative enough. Or at least could you help me get a barrel strong enough to with stand 5 elastics. If you could, please post up some designs. Or E-mail Them To Me At sockerpro@gmail.com
1-10 of 16Next »
I wouldn't use paper.... but I did make a bow out of a mechanical and an elastic band and the tip of a paper clip. STICKS IN THE WALL....(I was really bored in math class...)
Kiteman9 years ago
Laminate paper and glue?
awsome (author)  Kiteman9 years ago
I find tape to be stronger but the lamination wouldn't be a bad idea
jtobako awsome9 years ago
Laminations will give compressive strength, tape will resist tearing stresses. Are you making a modified 'T' shape with elastics on the arms of the 'T', winding the elastics under the stock like a diver's spear gun or trying to make the prod/bow work? Have you found a trigger mech that you like?
awsome (author)  jtobako9 years ago
For the trigger I have one of those paper clincher thingies so I pull the bullet back and have the clamp hold it in place. the only thing is the paper gets weskend after awhile and starts to collapse on itself
You'll need harder paper then : ) If you aren't using glue as a stiffener, then you are going to have to make some of the paper you do have stiffer. Layer up some soaked but not dripping paper then clamp it TIGHT between two boards or other strong, flat surfaces. You are trying to make MDF, so more pressure is best. Now let it dry for a week or so (less if you can stick it in the oven at no more than 200 degrees F/95 degrees C). Then again, if you are using tape, what's the problem with glue?
Its just that the glue will snap if you put pressure on it. the tape is flexible
That's where you need to know the difference between compression stress and tension stress.
Stack the layers like this |||||| on the inside of a curve and like this = on the outside of a curve. The trigger area is buckling because it's trying to curve up and the layers aren't strong that direction.
Oh, and use the strongest/longest fiber paper you can find.
matseng9 years ago
I have only a vague memory of the Mythbuster Crossbow episode. Did they succeed or not?
awsome (author)  matseng9 years ago
I think it was plausible. I just watched it the other day
1-10 of 16Next »
