loading
Paper two stroke hydrogen engine
 Ok so I have this crazy idea to make a two stroke engine out of paper that runs on hydrogen and well ive allready built part of it just the piston head and cylider and stuff but if i lined the inside of the cylinder with tin foil would that be enoth to keep the paper from burning? and so ya anyways the engine of i have made allready is very sturdy each peace is 10 sheets of paper or more compressed for over 24 hours
now the compression im not two worried about because its more of the sheer pop of the explosion that will push the piston down well i guess thats how it is anyways but if the gas ignites anyways with oxygen why have compression  for this anyways because the explosion is going to be soooo small anyways that it wont really matter much.
 the overall size of the engine is about almost 2" tall by about 1" wide on the widest part the bottom .
So um I know by now im classified as "CRAZy" but that asside can i get some opinions and ideas plz. thanks MRN
1-10 of 26Next »
lemonie7 years ago
A good diesel engine will top 40% thermal efficiency, you are not going to beat that, so t least 50-% of your thermal-energy would be going into the engine-block / exhaust. Paper is not going to work for you for very long. You'll have sealing problems too.
L
Agreed...and aside from that, the engine would not have any sort of application whatsoever, because the paper engine is not going to provide enough torque.  Perhaps PVC?
mrn (author)  kplatinum7777 years ago
 yes pvc would be good but the point is to see if its plausible to be done with paper and as far as the torque what do u mean by that? why would it make a difrence with paper?
NachoMahma mrn7 years ago
.  Paper, in any "normal" form, is not strong enough to handle the stress of a Hydrogen explosion. If it can, then you have the problem of converting linear motion to rotary motion. Throw a lot of friction into the equation. Unless you found your paper at Area 51, I just don't think it can handle it.
.  It's a great model, but you're not, IMNSHO, going to get it to run as an ICE. You might be able to run it at very low speed for a few seconds using compressed air.
.  But I'm no expert. See if you can make it work. Just be aware that it may blow up in your face and take the proper precautions.
I agree about the precautions and the potential for a BOOM on the first run but I like your grit.  I think if more people attempted the impossible and challenged normal thinking we would already be having tea on mars.
As it is, my two cents tells me that you should also focus on lubricant for a while.  You need to find something that will not degrade the strength of your paper or cause it to break down entirely.  Some lubricants can have solvents and in this case I think some will simply be a solvent.  This could help shield the paper from water(atleast for a while) as your lubricant could be hydrophobic.
Also, how do you define a paper engine.  Does it have to be 100% paper?  Just the load bearing areas?  or Just the cylinder?  Just thought it would be a good idea to define what a paper engine is to make sure you don't cheat yourself out of a truly awesome project.
Also, if you do get this to work and it actually has even the slightest torque I might try to build one and use it as an outboard for a cardboard boat.  The judges at competition would be blown away.  LOL.
Qcks7 years ago
Paper is a lovely composite material, but it doesn't have great wear resistance. In fact, wear resistance is probably more of an issue then heat.
Moving parts made out of paper, especially if they move while in contact with something, don't hold up very long. Paper is actually a very mild abrasive, with finer grades of paper having less grit to them.
You might experiement with an aluminum foil lining to improve the wear resistance. Aluminum can rub on things and it doesn't intrinsicly degrade other materials as it does so.
As for heating issues, obviously a heat stabele glue is a must, but... something that might help that maybe you haven't considered is the fuel.
A number of small hydrocarbons produce freezing effects as the rapidly evaporate at atmospheric pressure. If your engine had a small amount of liquid fuel added to it, it'd help cool the cylinder and increase comp[ression as the liquid became gas. There's a number of lighter fuels (like the type used in Zippo's) that'd work for this.
mrn (author)  Qcks7 years ago
 Ya i actually have put a tin lining in in the cylinder head after i took the pic i need to update that actually but anyways the fuel i am using to power it will by hydrogen and ill make it by the splitting the water with a battery ive got the system worked out see my diagram down a few comments.
and the paper isnt just a sheet its 10 to 12 sheats glued and cut to the shape i want and is very sturdy. but yes i agree the friction could be a problem but with the tin i think it will be ok.
Qcks mrn7 years ago
One of the few problems with hydrogen is that it puts out alot of heat compared to other types of fuels.
Where the paper will act as something of an insulator, thus retaining heat, this could quickly become problematic.
As for the tin, it'll weather the mechanical wear as well as aluminum, but it has a habit of melting at relatively low temperatures. That's part of why Tin is used in solder.
I think this is a cool idea, but I'd be a littel concerned with how it's gonna work out.
 ya im reasearching what the temp of witch tin melts i really dont think that will become a problem because the explosions will be so small and ya having a bunch within a few seconds will wear and possibly melt the tin but ill come to that when i get it atleast running.
but yes i might have to put some other kind of liner in side.
Qcks mrn7 years ago
I should be clear... I think this is a nifty Idea, but I like to layout what I see as the engineering challenges to accomplishing this task.
The wikipedia list's elemental Tin's Melting point as 231.93 degrees celsuis.
It also states that Tin has a specific heat capacity of 27.112 Joules per mol per unit kelvin.
The Wikipedia goes on to say that the enthalpy of combustion for hydrogen is -286 Kilojoules per mol.
This information coupled with the pressure that you're running the motor on will tell you how quickly it will heat up and thus how fast you have to get rid of heat to prevent it from reaching 232 degrees celsius.
1-10 of 26Next »
