loading
Part of iPad Screen Not Working after Replacement
Hi! I replaced the digitizer on my iPad 2. It was damaged in 2 separate drops and the screen was completely shattered. It was working fine before I replaced it. Took me 2-1/2 hours to get it off and clean up the glass and I had to grind flat two of the corners with my Dremel Tool so the replacement trim and the digitizer would lay flush with the frame. After I installed it, the iPad fired up just fine and was working, just there is a 2-1/2 inch section of the screen (about 4" up from the home button) that wasn't responding to touch. The top 1 inches of the screen worked fine, and the bottom 4" worked fine. I tried reseating the digitizer cable numerous times with no effect. I heard it's supposed to fit into the connector with the white dots flush with the connector, but it won't go in any further, even when I pushed it with my plastic pick. I was very careful in removing it and didn't damage any cables (WiFi, power, volume) or connectors. However, I did rub the sleep/wake sensor with my spudger and roughed it up a bit. It's not completely destroyed, but you can tell it was molested 8(
Is it possible that in damaging the sleep/wake sensor that it would make the screen behave that way? Could it be the digitizer being faulty? I got it off Amazon for cheap. I am doing an RMA on it soon. If the replacement digitizer doesn't work, then I don't know what to do.
Any suggestions would be appreciated!
Thanks.
Nick
Sounds like a faulty digitizer. If the replacement doesn't work then the iPad itself may be damaged.
NickB6 (author)  mpilchfamily2 years ago
Thank you! So would the sleep/wake timer cause the screen to act up? I don't know much about iPads or how that thing works, so I am not sure if it would mess anything up.
I will let you know if the new digitizer works/doesn't work. If it doesn't work, then we'll have to live with the screen partially working because by the time I've sent the digitizer back I've almost paid as much in shipping as the digitizer cost.
Nick.
