Partial solution to trash in water? Maybe.
the first one, this one has a couple of flaws: This is a very basic idea to skimming trash off the surface of water, a net. Preferably one with small holes to limit the amount of trash flowing out of it with the water. BUT, fatal flaw: It can also catch wildlife in it, and I'm still trying to figure out how to work around this. Any suggestions?
Second, a filter of sorts for storm drains/streams: Imagine a metal mesh wedge, kind of like a snowplow wedge, that would go in front of drains and such (I'm thinking more for the type of streams and drains that have those big tunnels going under roads and sidewalks and emerge on the other side). The wedge could allow water to flow through, but direct trash off to the sides to collection tanks. I'll try to illustrate it below.
- - - - - - - - <0 (the lines would be the stream, then the wedge, then the drain/tunnel opening. I couldn't do the tanks...)
I'm eager for any suggestions/tips, improvements, and thoughts on these!
6
comments
Add Comment
L
L
It needs cleaned occasionally, as floating debris does eventually block it.
Yeah.. I figured that might be part of it.
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
