Piggy Backing a lithium battery (cell)
1)Many lipo batteries have 3 or 4 contacts, one is -, one is +, and the others are typically data or something. can I simply connect additional lipo's (just the + and the -) in parallel with the corresponding contacts in the device?
2) Are there any ill effects of charging (presumably from the built in charger of the device, like a cell phone) and discharging (using the device) parallel lipo's?
3) They will all have the same voltage rating, but do they all have to have the same mah rating?
thankyou
15
comments
Add Comment
2) Discharging might produce different charge levels, see above. Charging will most probably not work. If you connect the data lines (I guess that are the terminals of the charge controller inside the lipo pack) you can either only connect one of the pack, so the other is charging uncontrolled or connect them to both, what probably wont work at all.
3) Theoretically yes. I say theoretically, because I would not try this and do just strongly advice against paralleling lithium power packs.
During discharge, wouldn't all of the batteries be forced to stay at the same voltage level? For example, if you had a 1000mAh battery and a 100mAh in parallel, wouldn't the circuit just automatically draw more current from the larger battery and less from the smaller battery (since all the batteries are at the same potential).
2) I don't see how discharging would cause different charge levels. When discharging packs involving series cells, I can see how it would happen, but not with a parallel pack for the arguement above.
3) Already adressed
Oh, and I wouldn't be connecting data lines, I would only connect the battery terminals of the bare cell to the cell in the phone where that cell's circuitry will talk to the phone.
The only reason I'm asking is if I'm missing something intrinsic to lipo batteries, after all I wouldn't want to mess up a larger battery pack (for safety and financial reasons).
Also, the internet is not providing clear cut answers, there's people with the same reasoning as me, others who say it'll instantly blow up, others that say you need a boat load of saftey circuitry (which I believe is nice, but in all honesty I think can be skipped in low current draw situations like this, after all thin wires will be going from the cells, which'll melt before catastrophic failure), and others that say you need to have an even number of cells in parallel (which makes 0 sense). There's also products like this:
http://www.sparkfun.com/products/8484
which is just 3 cells in parallel. They do say they were matched for internal impedence, but I'm wondering if that is even relevant for the arguement made in number 1
SInce the batteries are going to have different length wires, and therefore resistance, different voltages will become established over several charge/discharge cycles.
Capacity is not equal to internal resistance. Batteries of different capacities may or may not have identical internal resistance.
Steve
I totally get what you mean with the internal resistance, however I do not believe it will provide unbalance in cells. If one cell has relatively high internal resistance, there will be a relatively large voltage drop across the internal resistance and have a lower output. However, this output must equal the output of all the other lipos which have are in a similar scenario. Therefore less current will flow from the battery with higher internal resistance.
Therefore the batteries with lower internal resistance will drain faster.
However, as they drain faster, their voltage output drops, creating a larger current draw from the battery with higher resistance.
hmmmm, now I'm starting to second guess myself.
I want to say it's fine as long as the internal resistances are fairly close, but how close is fairly close?
ugh
(Another variable is the knowledge level of the internet commentators, of course.)
Go on, if you want to try - but don't rely on the on the thinness of wires as a fuse, put in some real fuses - you can get tiny ones that break down at a defined current.
What I don't get is 'why' you want to do it. Making a device run longer, that's clear, but if you connect two batteries, they will not fit into the case, making your cell phone, tablet whatever look quite ugly and probably no longer really portable.
If it is for use at home, just use a wall wart - cheap and no need to charge at all. If it has to be portable, buy an extra battery or two. Instant doubled (tripled) time of use. No safety concerns, no loss of warranty, no ugly add-ons. If the original batteries are to expensive, try to find some cheap copies, they might last not as long but normally work quite well.
Only an even number of cells parallel? Ridiculous. I'd say use only an odd number of cells parallel: One. Anyway, if you want to test it, go on, but play it safe.
Maybe that might help.
http://www.rcgroups.com/forums/showthread.php?t=932319
It seems like it's fine, actually even more than find considering these are 100% in parallel rather than parallel series combos. It just says make sure they have similar charge when first connected so that there's not a dead short surge like verence said.
http://www.rcgroups.com/forums/showthread.php?t=1422515
quoted:
They can be the same capacity or different capacities but must be close to the same state of charge (voltage) before connecting them in parallel.
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
