Plastic Soda Bottle Prosthesis
War, land mines, and natural disasters create far too many amputees each year, especially in the developing world. Worse, prosthetic limbs are expensive and hard to come by. The Center for International Rehabilitation, posting under Instructables username CIRNetwork, has been working to find sustainable solutions: locally available materials worked by local craftsmen.
Their plastic soda bottle prosthesis is one clear, simple solution to this problem: a plastic bottle is heat-shrunk to cover a plaster cast of the limb stump. Different devices can be attached to the end of the bottle, enabling the wearer to perform basic daily tasks. This type of thing can really make a difference. Check out the video below, and see more on the CIRNetwork YouTube channel.
Want to help? CIR is seeking donations of mobility aids to support ongoing rehabilitation relief efforts in Haiti. You can also make general donations to assist people with disabilities worldwide.
This post has been sponsored by Pepsi. The Pepsi Refresh Project celebrates the people, businesses, and non-profits with ideas that will have a positive effect on our world.
22
comments
Add Comment
I kinda find it funny that Pepsi is helping. All I see from them are coke cans, we need plastic bottles! Common Ozarka!
1) Use a second bottle, removing the spout, and shrink it over the first bottle. Possibly with some epoxy in between.
2) I would reinforce the end attachment part by making a piece of pcv permanently attached.
As noted in the original 'ible, the PVC is not attached permanently because this allows the terminal devices to be swapped out easily by just removing the hose clamp.
PLASTIC BOTTLE CAMERA ARMOR:
Make a positive copy of your camera: Cover it with a condom (or robber glove sleeve) and plastic wrap. Roll on a layer of soaked plaster bandage. Let harden and take apart. Coat with petroleum jelly or dish washing liquid. Re-assemble and fill with plaster. Let harden for several days, remove mold and polish positive.
Measure that the positive is as big as the camera. If not, tape a material like 1mm thick cardboard to the flattest sides -perhaps also over the display area, so the armor will be 1mm away from the screen.
Then do the same process as for the prosthetics, and cut holes where you need to access buttons and tripod threads.
Instead of pulling out the positive, you may need to destroy it to get it out; don't bang the plastic too much in the process, since that may discolor it.
Re: the Pepsi sponsorship, if a big company wants to put its money behind publicizing and funding good ideas I'm doing everything I can to encourage the behavior. Imagine if this became standard practice!
In theory, how hard would it be to make bottomless "bottles" with a slight cone shape so they could be stacked one inside another? Those could be shipped much more efficiently than full bottles- a stack of a hundred would only take up as much bulk as a few full 2 litre bottles, and they would cost a few pence each and function exactly the same way these do.
Free of the constraints of holding pressurised liquid, you could even customise the neck with a better type of opening for this type of clamp attachment- remove the screw threads, perhaps?
In fact, I think that would be a much more complex manufacturing step. These bottles are made by inflating a plastic blob into a hollow mold. You get the bottom "for free," and it has to be there for inflation to work :-)
To get a cylindrical/conical open shape, you would either need a two part injection mold, or you would need to make the bottle the way they do now, but then run it through a slicer to cut off the bottom.
You're also talking about a much more specialized, low-volume application, which means that the manufacturer can't amortize the capital equipment and maintenance cost over (m/b)illions of units. Instead, that cost gets spread over maybe a few hundred thousand units, which means the cones each cost at least 100 times as much as an empty bottle.
"Project Manager" is a nasty thing to call someone. I used to be one, and I'd never call anyone that. Especially if that meant they had to do the job.
As for the suggestion itself, keep in mind that this project is designed to be done, from scratch, within rural developing contries, with very little in the way of complex equipment. Creating a design that requires custom threading on pipe makes it harder to deploy, and harder for the people involved to do for themselves.
Definitely worth posting.
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
