loading
Plastics modeling techniques?
hey im and architecture student and im wanting to experient with a moldable plastic (in model building) to design a sculptural screen wall. To replicate a "nurbs" surface that is digitally modeled, so its all wavey and stuff. If anyone has any suggestions on material or modeling techniques let me know! thanks
sbolli (author) 9 years ago
i ended up making like a fan style thing and then put metal mesh over it.. then i needed it to be shaded so i painted watered down latex on it to give it a pixelated shadow effect. it was a total long shot but it actually turned out pretty sweet, ill post a pic up.
bw1.pdf(792x612) 8 MB
bw3.pdf(792x612) 8 MB
ball.pdf(792x612) 7 MB
caitlinsdad9 years ago
See if you can find this air hardening polymer clay. Create a "stamp" of your wall pattern from the clay. You can then use that to replicate a section of wall by impressing it and repeating the pattern into a sheet of new clay. The stuff does dry rock hard and the only thing to be aware of is that it may crack if it dries/cures too fast if the piece is very thick or too dry.
Hmm my friend and I both built architectural pieces for our art coursework, a combination of mod roc (like plaster paris but can be smothed and hold structures well.), Foamboard or mounting board, I had a bit of vacuum forming, there was wood involved and I used wire to create parts of the structure, they were impressive in the end, he made his as unfinished modroc and I plastered mine and sanded much of the outer surfaces down to a smooth touch.
