3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Poll:Do you use an EPROM PROGRAMMER?
1.Do you have an eprom programmer? 2.Have you recently used or thought about using an Eprom in a project? 3.If you don't have an eprom programmer, would you be interested in Making or having one? 4.Do you think eproms are obsolete? 5.Can you think of a use for an eprom? 6.Are eproms too unusual to use in a Make or Instructable project?
21 comments
Apr 3, 2009. 4:43 AMonkelf says:
sometimes. stole about 30 27c512 eproms so I've been programming som nes games on the eproms.
May 3, 2010. 4:52 PMchetreynolds says:
I am trying to reprogramj some of these chips wi8trh tke willem pcb5 with no louck. I programed some before but I caqn't fi8nd the coorect jumper conf. again . Can you help me ?
Feb 28, 2010. 9:41 AMljuben says:
 i have  SEEPROG programation and  a memory ship who dont work and i dont know have to put a new information and to get working.and the problem is how du i put some information on my computer then in the new one.PS.some one help me or tell me how to get it write
Feb 28, 2010. 9:40 AMljuben says:
Nov 19, 2009. 12:20 AMDouglas W. Goodall says:
 I know the electrically alterable devices are cool, but there is a warm fuzzy feeling I get when I put the opaque tape over the window and I know my bits are safe. At least it is more efficient than driving to culver city with a papertape.
I am into vintage machines and eproms are widely used in the original hardware.
I haven't actually used one in a decade, but I think fondly of them as I have used them over the course of my career for 6502, 8085, 80186...
Making SCSI boot roms for Apple ][ hard disk adapters was fun.
Jun 23, 2009. 6:53 PMglenncw says:
I have been trying to use a willem programmer to program a 2732 chip for my car. Unsuccessly I might add.
Nov 27, 2008. 5:47 AMhawksting says:
I currently have a few reclaimed EPROMs sitting on my desk that I'd like to use for a retro/restoration project. I'm going to have to borrow a burner, as I do not own one. It seems that EPROMs can still be recovered easily from older equipment...in the days when manufacturers used IC sockets.
Nov 13, 2008. 5:34 AMScucci says:
I use my Eprom programmer at least 3 times a week. I'm currently restoring a Tron arcade machine right now. It was converted to Two Tigers, so I bought an Eprom programmer and eraser and converted it back to Tron by programming some blank eproms. I had to do that because of how hard it is to find original chips that haven't suffered bit rot. They might be considered obsolete, but for some projects for those of us that don't throw everything away in favor of new technology, they're still very important.
Nov 13, 2008. 8:15 AMwestfw says:
Ahh. Arcade game restoration. That makes a lot of sense! (Post some instructables on the topic!)
Nov 13, 2008. 9:19 AMScucci says:
Not interesting enough... atleast Tron isn't. But I should be getting an empty Robotron cabinet soon... and possible a broken Asteroids that would make much better topics.
Oct 20, 2008. 7:20 PM11010010110 says:
implement in software > flash/eeprom > eprom > duct tape
Oct 17, 2008. 7:05 AMlewinskys says:
I restore old Arcade Video and Pinball machines, so I use my Epprom programmer and UV eraser a lot.
Aug 23, 2007. 8:28 AMchooseausername says:
1.No 2.Yes 3.Yes 4.Yes 5.Yes 6.Maybe ...
Aug 23, 2007. 7:19 AMWitte says:
I often use my Eprom Programmer to update existing Eproms. Therefore I can say that for service reasons, Eproms are still important.
But for developing new devices, most companies are using Flash Eproms or using microcontrollers with embedded flash memory.
Apr 14, 2007. 3:24 AMwestfw says:
1) I have a Needhams EMP-10 (20?), and I've used and/or have access to a bunch of others. 2) Haven't used an UVEPROM in many years. 4) I think they're pretty obsolete. In most cases you can get flash or eeprom in similar size and package at similar prices, and serial eeprom MUCH cheaper. 5) Um, I can think of some apps for parallel DIP-28/DIP-32 Non-volatile memory, but none that require UVEPROM. 6) You can publish with a note to the effect that parallel eeprom or flash or even NVSRAM can be used instead to cover some bases, but... buying obsolete tech (both chip and perhaps programmer) can be painful. NVSRAM is common in the dumpsters I frequent. :-)
Apr 18, 2007. 7:45 PMwestfw says:
You can do a multi-digit decode with an 8bit-wide EPROM? I do have a fair set of EPROMs in my junk box, but I'm afraid it's unlikely to be "typical" anymore. To get things to go as fast on new computers as old ones, reduce memory and disk size to the minimum required and revert to a command-line interface instead of using a GUI. For instance, things like tomsrtbt boot and run very fast, even from a CD...
Apr 18, 2007. 10:18 PMFrenchCrawler says:
I was thinking of making one, but decided that it would probably be best to try and buy one that allows more types of chips to be programmed. Right now I have my eye on this eBay Seller and waiting to save up the extra money...
Apr 14, 2007. 2:24 AMtwoedge says:
I remember burning EPROMs for VT100 monitors in the mid-80s. I thought it was kinda mystical placing the EPROMs in the uV lamp eraser. I still have a few of the EPROMs on my desk stacked next to a Pentium chip, some vacuum tubes, a 14" hard drive platter and some saved viruses on write-protected floppy disks.
Mar 23, 2007. 3:25 AMian says:
Why not? These are almost antiques, eh? It seems everything is using cheaper EEPROM and flash now. I have personally never been exposed to this type of chip, all my uCs are EEPROMs or flash memories.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
