Could someone recommend a dc motor strong enough but @ the same time gentle enough to be used for power assist. The item will be a custom built dolly used for lugging around camera equipment. The total weight will be approx. 50 - 75 lbs. Thank you to those that help.
So I really will need a heavy duty motor, I was hoping that I'd be able to avoid that, but, I want this to be a high quality project. Ok that's out of the way.
Don't wiper motors work in a oscolation motion or is that an eccentric attachment? I'm automotive inclined but not to that point lol.
It's going to be used on both hills & flat surfaces. The pace will be just about normal walking pace. Basically it is just going to be taking up the slack so I can tote everything around easier. I have a really bad back & a worse leg, so carrying this stuff isn't an option.
die grinder? electric chain saw? starter motor? belt sander? most of those don't really have the torque (save the starter motor) to start a loaded dolly from a dead stop, but they would definitely reduce the amount of pull required to get the thing moving.
for all of those you'd have to develop some kind of gearing, a battery pack, and a speed controller though.
if you did as the man of kites suggests and get a junk electric wheelchair or like a rascal scooter or something, you'd already have the drive train, power source, speed control, etc.. check around on craigs list i bet you'd be suprised at how cheap you can find some of the components.
If you want something like those pallet lift assist dollies, maybe make a version of this http://makeshopshow.com/2012/05/14/drill-powered-skateboard/ You might want to get a flex drill shaft or metal rod to extend a drivewheel so the drill is at handheld height.
Bio:I'm a MTF transgender & I'm starting up my own stempunk themed business & some of the things that I'm going to be doing I'll put on here but also the people here can help me learn how to do things I d...read more »
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Are you always running on the flat, or do you want to (try) pull up hill ?
How fast do you want to move ?
The final item has no need to end up looking like the donor vehicle.
