COMMUNITY : HELP : BUGS
Problem Updating The Instructable - Error
I couldn't save the instructable I'm working on. Tried to edit it, delete the whole thing and create a new one but I still get the same error message "JSON.parse: bad control character in string literal.
Please see attached screen shot for reference and hope you can help me out on this.
frenzy says: Oct 8, 2012. 10:13 AM
This is often caused by using a special character, are you using any special characters in your instructable?
mygms (author) in reply to frenzyOct 14, 2012. 7:20 AM
Nope, not using any special characters. This is the only instructable I'm having a problem with.
BrittLiv says: Oct 8, 2012. 1:16 PM
I've got the same error in one step of my newest Instructable: http://www.instructables.com/id/Mayan-Rubiks-Treasure-Box/#step1
I get it every time I try to edit the step.
I've got the newest JAVA version, tried it in the latest firefox and IE versions as well as in ubuntu and windows... With no luck.
mikeasaurus says: Oct 8, 2012. 9:48 AM
a JSON error is due to JAVA not loading on your browser correctly. Make sure you have the latest version of JAVA for your browser, along with no script blocking add-ons (like Ad block or any of the other browser add ons I can see in your screen shot).
StumpChunkman says: Oct 8, 2012. 2:20 AM
Hey mygms,
I think there was probably just something gumming up the works. If you try again (to make the instructable from scratch) I think everything should work fine. I went ahead and deleted that one for you.
I saved the text from the instructable in case you needed it, if you do, please pm me and I'll send it to you straight away.
Please let me know if you have any more troubles!
-Stump
Kiteman says: Oct 7, 2012. 11:09 AM
Kudos on the screen-shot.
Bug report filed.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
