loading
Propane in air compressor hose
Does anyone know how a regular (150psi rated) air hose will stand up to propane? I'm curious as to whether it would dissolve it.
1-10 of 14Next »
SqiarB10 months ago
I'm glad to be reading this article, I simply want to offer you a huge thumbs up for your great information.
Tableau Guru
www.sqiar.com
Toga_Dan11 months ago
http://www.pveng.com/ASME/ASMEComment/DualCert_LowTemp/DualCert_LowTemp.php At 100 deg F, propane will be about 170psi in the tank. (regulator will bring that pressure down)
Toga_Dan Toga_Dan11 months ago
110F -> ~ 200psi.
Maybe this is why propane tanks get painted WHITE.
BenB10311 months ago
Polyurethane would be your best choice if you wanted to use air hose for propane. polyurethane is resistant to a LOT of oils and gases. Heres a list. Thanks Ben
dmcgraw77 years ago
Years pass... Most propane fills also contain butane. The cheaper air hose is PVC and butane softens PVC so stay away from that. The better air hose is polyurethane. Polyurethane is probably ok for short-term propane use, but it will dry out, crack and leak sooner than the correct hose. Propane leaks are a bad thing because propane is heavier than air and will pool up in a boat, RV or truck bed. Butane/propane rated hose is a nitrile (aka Buna-n) tube reinforced to a 350psi working pressure. Nitrile has excellent resistance to petroleum-based oils and fuels. PU 300psi air hose can be had for less than .50/ft. Nitrile 350psi hose is $2 to $5/ft. I wouldn't use PU in a boat or RV or anywhere propane could pool up, but I might use it with a weed burning torch or something that is only used infrequently. It's always a pain to figure out what plastics and elastomers are appropriate. I found this site to be helpful: http://sealingspecialties.com/materials.htm.
Austringer9 years ago
What are you trying to do and how far do you have to go with it? Copper refrigerator tubing with a regulator on the tank end of things and two swage lock fittings would be my advice.
Hegemone (author)  Austringer9 years ago
It's actually for a propane fumigation system for a diesel engine...has to run from the bed of the truck forwards. Just wondered what I could get away with when that long of a section of propane hose would cost near $100...wonder what the pricing on a section of copper would be.
jonjr9 years ago
I say cut the hoses open and see what the propane hose has that a air compressor hose does not and if there the same then you might have a winner. hope this helps
NachoMahma9 years ago
. There is a good chance that the propane will be incompatible with the air hose and the "rubber" will decompose. It may work temporarily (a day or two), but is not safe for long-term use.
Goodhart9 years ago
Solubility sounds like a possibility.....Benzene, propane, methane and vulcanized rubber...
1-10 of 14Next »
