loading
Question about electric motor ratings
So, lucky me, I curb surfed a table saw last friday, I was going to part it, but my wonderful wife suggested that I could benefit from an extra saw. So deciding to fix it up, I looked over the motor rating, and was left with a question. The motor is rated at 1&1/2 Hp 110v 18 amps. So my question, When is it 18 amps? Start up? Running? Stall? I ask because my breakers are 20 amp, kinda close there for comfort, and no re wiring for 220 right now is not an option.
Tool Using Animal (author) 10 years ago
I guess I'll determine it empirically, get it running and shove a piece of thick dense wood into the blade (I won't be that cavalier, i do know what i'm doing) if it pops the breaker, oh well. BTW first time i plugged it in, it popped the breaker, but a little 3in1 Oil on the motor bearing and it ran.
leevonk10 years ago
just test the internal resistivity of the motor. (put a multimeter across the power and ground wire)
Then V = I * R
110v = I * MeasuredR
the I you get will be the running current, if 18amps is way above that, then 18amps is the stall current.
does that work for a/c motors too? I would have thought there's an inductive resistance (iono, I'm not a super duper electronics guru :P)...
I'm not sure,... I'm no guru either. This is basically what someone told me a few years ago aboutn some othedr motors
trebuchet0310 years ago
I'd say that's the stall rating... At least I would hope so -- I really don't care what the running current is. I just want to know worst case scenario (stall) so I know where to plug in :P Just plug it in and see what happens ;) If your trip the breaker easily.... then part it ;) Otherwise, go forth and conquer :P
Crash210810 years ago
I would assume running. Don't know about load, though...
