loading
Questions about AC motors and removing printing from canvas tote bags
I found ahem dived for a motor a few weeks ago that runs on ac. Could I use 2 relays and a 555 to get 60hz AC with a square wave or does it have to be a sine wave to run properly?
Second question:
How do you erase fabric paint or screen printing from a canvas tote bag?
Thanks
NachoMahma8 years ago
. Most AC motors aren't real picky about how clean the incoming power is - variable speed drives are notoriously noisy. It should run OK with a square wave unless it it under full load, but will run warmer and may make a little more noise. If you only have ~50% load, or less, on the motor, you should be fine.
. Just to clarify, if you feed it a square wave under full load, you will more than likely burn it up. At half load, no problem.
LinuxH4x0r (author)  NachoMahma8 years ago
Well then, I guess I should find a different motor
gmoon8 years ago
I have my doubts about using relays for the switching... for a clean 60 Hz sqr wave, anyway.
To get rid of the printing try putting it through several hot washes and tumble dryings then it should be flaky and easily removable... Not too sure bout the motor... Haven't seen anyone running any projects on non AC, because it seems simple to run it on mains...
