3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Rebuilding NordicTrack ski machine drive rollers
I know NordicTrack ski machines have largely been replaced by elliptical machines, but the ski machines are still very good for a great upper and lower body exercise regimen. I have talked to people who say they just plain wore out a ski machine. The part that wears is the one-way clutch inside the drive rollers.
NordicTrack makes strong mention of the patented flywheel and drive rollers invented by a mechanical engineer whose hobby was cross country skiing. When the drive rollers do wear out, the owner can order new rollers for $65 to $95 (depending on the vendor), or he can send his old rollers to Nordic Track Guy and have them rebuilt for about $33. But, what I finally figured out today is that the mysterious one-way clutch is actually a very common item you can order from Amazon or probably pick up locally at a shop that sells bearings of all kinds. The name for the one-way clutches is a one-way needle bearing
The photo is of a portion of the back cover of the manual that came with my machine. It shows a cutaway image of the drive roller. The black printing is mine. Notice the three cylinders inside the drive roller. The outer two appear to be bronze sleeve bearings. The center one looks like a roller bearing, but is almost certainly a one-way needle bearing. A one-way needle bearing is essentially a roller bearing, but the rollers are able to move forward and backward a little in their cage. There is a wedge shape for each roller that causes the rollers to bind between the bearing cage and the shaft when the rotation is in one direction, but they are free in the other direction. Here is a description of how they work with graphics.
I have not taken my NordicTrack ski machine apart, yet. It still works fine. But, when one or both skis slip and no longer make the flywheel turn, I will look seriously at rebuilding my own rollers. I already know the shaft is 5/8 inch in diameter. A common size of one-way needle bearing is 5/8 ID x 7/8 OD, which I suspect is what is used in a NordicTrack drive roller. There appears to be a bronze sleeve bearing on each side of the one-way needle bearing. A socket the right external diameter from a wrench set would make a good tool for driving out the old bearing and driving in the new bearing. It looks like I would need to remove both sides of the NordicTrack ski machine frame, but that is not hard.
The one big advantage to rebuilding the drive rollers myself would be turn around time. Sending the drive rollers away for rebuilding means a one week turn around. If I acted quickly, I could have the new clutch bearings replaced in a day or two. (If and when the drive rollers fail in my NordicTrack, I will make an Instructable.)  If I did the rebuilding myself, I would save a few dollars, but not many. That would depend on where I got the replacement one-way needle bearings and how much I paid for them. The drive rollers are supposed to be good for five to ten years of continuous use.
13 comments
May 23, 2012. 5:16 PMkelseymh says:
Phil, this is awesome -- and your wonderfully DaVinci-esque drawing makes it complete :-) Please, oh please, find a way to make an I'ble out of this! Even if you have to borrow someone else's pictures of the machine :-)
May 23, 2012. 7:12 PMkelseymh says:
Really? ....I should have read all the details; you actually said that. Still, it's a much nicer picture than I would normally expect from an owner's manual :-)
I completely understand not wanting to open up something that is working properly. I've broken more than one item (including the first of my daughter's crib aquaria!) by doing that.
May 24, 2012. 8:40 AMkelseymh says:
:-D Thanks! Perhaps they're trying too hard?
May 22, 2012. 10:37 AMk24tea says:
THANK YOU for posting this information! I hope you'll make an Instructable for this. Meanwhile, I'd really like to try it now. The drive roller clutches have failed on my Nordic Track ski machine, and I would love to know how to rebuild them myself.
I can remove the drive rollers, but I don't know anything about one-way needle bearings. I'm handy with small tools and parts, so if you can please give me any further info on what to get and how to rebuild the clutches, I'm pretty sure I can do it. I agree, it may cost about the same to ship them off to Nordic Track Guy for rebuild, but the lost time on my beloved Nordic Track is priceless! Thank you for any assistance you can offer. kt
May 22, 2012. 6:00 PMk24tea says:
Hi Phil,
Wow! Thanks so much for this very helpful information and advice! I'll try to dig up my Nordic Track manual (haven't seen it for 20 years) and look for the drawings you describe., or I think I saw the manual available for download. There are a couple of places around here that might be able to help me get the bearings I need and maybe press them out/in for me or else show me how to do it. If I can find the right size bearings and can replace the old ones successfully, I'll send you an update with part numbers. Otherwise, you're right, the Nordic Track Guy can rebuild the drive rollers for me, but so much more rewarding to learn how to do it myself. Armed with the excellent instructions and advice you've provided, I think I can do it! If I do an Instructable on this, I'll be sure to credit you and link to your posting as the original contributor. Thanks again! kt
May 23, 2012. 6:42 AMk24tea says:
Thanks, Phil, the drawing helps a lot. I'm tempted to take a drive roller apart now, just to see how it works, and then if I can't find the parts or mess it up somehow I can still send them out to NordicTrackGuy to rebuild. But your description and instructions are so good that I'm confident I can do it (famous last words). And I'll learn something new, so it's all good.
Maybe after you retire from your current job, you can make more Instructables and/or teach your skills to folks like me who just "need to know" how things work. You clearly have a knack for describing and explaining.
I hope you'll find time soon to use your Nordic Track again. I know what you mean about fatigue during busy times, and sometimes it's hard to find time and energy for anything besides work. I've used mine pretty regularly for about 20 years, and I find that a NT workout with my favorite oldies music actually increases my energy and elevates my mood for the rest of the day. My plan is to stay strong so I can have the energy to do what I want to do! Thanks again, Phil, for helping me stay "on track".
May 23, 2012. 3:58 PMk24tea says:
Thanks, Phil. I think I need to take my drive rollers out now, just to see inside them! An interesting rainy-day project, and if I can't repair them after all, then they will be sent on their way to the Nordic Track Guy. I've learned about one-way needle bearings, I'll get a little hands-on experience with something I've never seen before, and my machine will get fixed either way.
I saw your Instructable the other day for adding the wheels, and I thought it was a really good modification. The little wheels they come with are only good for shifting them a short distance. I can't imagine moving my Nordic Track up and down stairs more than once a year, or preferably less!
I'd like to see how you did your arm cord guides. The arm cord on mine snaps and flays about, and it sometimes flips over the top and needs to be re-wrapped around the drum, so I need to make something to keep it in place. I don't have your welding skills or equipment, so I'll probably make some guides with sturdy wire instead. Or my arm cord may just need replacing after 20 years of use. I read somewhere that a new cord is stiff, and mine is quite flexible, almost like a jump-rope. I've only done minimal maintenance on my Nordic Track until now, so it's probably time to replace a few parts to keep it going strong.
Over the years I've added just a few little conveniences. First thing, I mounted a small fan on top of the post. A long time ago I bought a combination book/music player/water bottle holder that mounted on top of the upright post, but it was brittle plastic and broke apart, so now I'm working on a little metal rack for mp3 player and water bottle to hang on the back of the hip pad. Sometimes making things for my "toys" is as much fun as the toys themselves!
I know what you mean about how good it feels to be in shape just to do ordinary activities more easily. I keep going on my Nordic Track in the hope that I'll keep my strength and mobility as I age. It's easy on creaky joints but still gives a great workout even when I'm not good for doing much else that day. I've tried several different ellipticals and treadmills, but I find my Nordic Track works just as well and is much kinder to my knees and hips.
Something I've found out about the various models is that most of the differences aren't terribly important to the practical functioning of the machine. There are different woods, and some are composites instead, and some have adjustable front legs for incline skiing. Some come with electronic pulse monitors and timer/calorie/distance meters. Some have a cable and turn-knob for adjusting leg tension instead of a simpler sliding lever connected directly to the spring and strap. Thus, some require different replacement parts than others. But all the original (pre-1999, US made) ones seem to be essentially the same as far as practical function and durability. I have the Achiever model; my sister has the Excel, and a friend has the Sequoia. They look a little different and the leg tension adjustment methods vary, but I can't feel any difference when I use one or the other of them. I think the most basic model is just as good and durable as the fancier high-end ones, and probably is easier to maintain and repair. No matter which model you have, you've got a great exercise machine!
So here's to you, Phil, for your excellent advice and instructions. I'll be reading your other Instructables, too.  Stay motivated, and keep on Tracking!  kt
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
