3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Remove a LED from... anything
I have a DVD player in my bedroom with a LED on the front that is really annyoing. Is there any reason that I couldn't open it up and cut/tape off the leads to the LED without any ill effects? Are there really any limitations to this? Thanks for the response.
9 comments
Jan 10, 2009. 1:22 PMLogin258 says:
Maybe cut it off and replace it with an IR LED that has the same voltage rating and such. Then the DVD player is doing the same thing, but you can't see it.
Jan 10, 2009. 3:31 PM11010010110 says:
and you can still see it with your webcam :) but i think its not essential part of the player
Jan 9, 2009. 3:39 AMlowercase says:
indeed electrical tape tape has been the ancient remedy for this. just go with the flow and don't mess with you're devices just to turn off an LED. That's totally overkill.
Jan 8, 2009. 6:19 PMguyfrom7up says:
removing the LED will not affect anything else, it's purley there as an indicator
Jan 8, 2009. 7:39 PMGoodhart says:
UNLESS you accidentally end up crossing the wires when you snip, creating a short , where a load was before. . .
Jan 8, 2009. 4:09 PMalex-sharetskiy says:
i'm with the whole tape idea
Jan 8, 2009. 2:50 PMwhatsisface says:
If you ever want to sell it on, I reccommend taping over the LED inside the case with some electrical tape, then it'll just look like the LED isn't on, and is easy to undo if you sell it etc..
Jan 8, 2009. 2:47 PMguyfrom7up says:
sure, cut it off BAM!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
