Removing Broken Pin from an RCA Jack
I recieved a free, working TV the other day. The only problem with it was the pin from an RCA video cable had broken off inside the socket. I didn't want to spend money on an RF modulator for my DVD Player, so I figured out a pretty solid way of getting the pin out.
1.) Find a needle
2.) On a hard surface, bend the very tip of the needle slightly so that it forms a tiny barb.
3.) heat the tip of the needle with a lighter until it glows red hot.
4.) stick the needle into the plastic core of the broken RCA pin
5.) wait a few seconds for it to cool
6.) pull the needle out, and the broken tip should follow!
Lomography Konstructor - World's First 35mm DIY SLR
Office Warfare Book on Sale Now
List of Upcoming Contests (updated 6/6)
Spanish translations of Instructables / Instructables traducidos al Espanol
JULY 2013 Build Night with SUGRU
High-current, electronic sword-fighting, fancy drink pouring, and more @ Makers Local 256 Build Night!
New Instructables Books for 2013
Souped Up: Projects to Make Everything Better [Book]
Backyard Rockets Book on Sale Now
Visit Our Store »
Go Pro Today »
just some notes id like to add.
i found safety pins work best, needles snaps too easy. get a decent size safety pin too. i used a small and a medium sized one and it wouldnt pull out. i had to go buy a larger size pin and it worked.
pull upwards. when i started pulling i thought leaning towards the metal barb/bend and pulling would be more effective.
my broken tip is still stuck in side the rca connector. i had some cheap crappy rca cables broken inside and the outside of the pin was made of metal and inside was plastic. anyone got some tips on getting the rest of the pin out?
You saved me money and lots of frustration while dealing with the repair guy.
just wondering only the plastic part came out..what about the top metal coating ?
In my case the sound system still works fine.
i tried everything then i opened up the TV and now that i decided to electrocute myself , i thought why not Google it as well. then i found this very useful instructables
GOD BLESS YOU
This isnt an instructable. There are many of these in 10 times better! if you just click one of those tabs on top :)
All I need now is just to change rca plugs. THANKS!
Huzzah!!!!!
I made sure I got a needle for upholestry which was long as well. I threaded the needle with heavy duty button thread. Then heated it with a "Candle" lighter. I slowly inserted the needle into the PIN. Waited a good minute for it to cool. The heat conducted in the needle smoothly pirced the plastic pin inside the AV plug.
I then utilized the thread on the needle as leverage to pull so the needle would not slipp out of my fingers.
NEW TV SAVED!!!! Thank you Thank you Thank you
Thank You
Thank you. It worked like a charm. I signed up to say this.
