COMMUNITY : FORUMS : CRAFT
Removing the stamp on a bulb
Hi!
Just a really quick question: Is there a way to remove the stamp on the bottom of a light bulb (you know, the bit that says the number of watts and the manufacturer) without damaging the bulb?
Thanks for the reply.
Kiteman says: Oct 8, 2012. 7:12 AM
Have you tried warm soapy water and a gentle scouring pad?
TashaDax (author) in reply to KitemanOct 8, 2012. 9:47 AM
I did indeed. It refused to budge :(
Kiteman in reply to TashaDaxOct 8, 2012. 10:54 AM
Next, try solvents - start with acetone (nail varnish remover), or a drop of WD40.
TashaDax (author) in reply to KitemanOct 18, 2012. 10:31 AM
Turns out it needed some vigorous rubbing with a steel scouring pad, as opposed to the one that comes on the back side of a sponge and after that some detergent, because (for some reason) the letters leave a greasy marks on the back. Thanks for the help :)
ChrysN says: Oct 9, 2012. 9:33 AM
I think it varies with the type of bulb some come off easily. Try steel wool.
iceng says: Oct 8, 2012. 10:35 PM
In the US the Volts & watts are glazed into the top of the glass.
After years they become so very faint that it becomes hard to read..
So I would surmise prolonged heating could help remove the text.
A
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
