3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
RepRap the next big thing?
Im interested in the RepRap project but is it me or does it seem to be relatively unknown to most people, even those who would be interested in this sort of thing? Something like RepRap would pave the way for so much possibility with easier and more complex diy projects, once it gets easy and widespread enough for anyone to make we will see some amazing things being done, this is the sort of enabling technology that we've all been looking for!
15 comments
Jul 22, 2010. 11:14 AMshakespeare1212 says:
Is there anyone near the Santa Monica, California area who would like to get together to try to build 2 reprap mendels? I have enough funding for one entire machine, and that means that you can get, if you buy the plastic, 60% of your machine for free. The projects looks a little daunting to take on by myself through. Of course, we would document the whole process and put up an instructable here on instructables.
Feb 16, 2008. 1:30 PMservant74 says:
I have thought of taking one of the home CNC type machines and putting a reprap or fabber head on it to play around with the concept. Has someone else already done this?
May 15, 2007. 5:09 AMBrennn10 says:
Is this a new fad? In Popular Science they have an item called the "Fabber" which is remarkably similar to the RepRap. This is cool!
Feb 16, 2008. 1:28 PMservant74 says:
There are two open source projects going on. fabathome.org and reprap.org .. There could be others, these are the only to I know anything about. The fab@home folks seem to be pointed to making 'squishy' things from extrude soft stuff, like caulk compound or chocolate. Material is typically fed from some kind of syringe for extrusion. RepRap seems to be focused on making 'hard things'. The typical 'print' head is a heated extruder that has a motor and a drive screw. Really very ingenious. This allows using a continuous feed of plastic filament. The plastics they want to use are totally recyclable. I am expecting them to design a recycling extruder, that would take ground up (or otherwise pulverized) plastic and generate the filament needed for their extruder. Everything in the RepRap design seems to be modular so one part can be replaced without having to do a total tear down/rebuild anytime something changes. As far as being able to go purchase and just use it, I think fab@home is further along. And their device, even 1st generation, looks really need if you have it laser cut! It seems to work pretty well. The DXF files and a vendor is listed on their web site that will cut them for you. RepRap started with the idea that people could make machines that could make themselves for the most part. But it would be an evolutionary process. And sofar it is. At first all the electronics was home brew made on perf or strip boards. Now commercial boards (and other machine pieces) are available. I think in Europe that someone is selling a complete machine kit. But the technology keeps changing and is getting faster, simpler, and cheaper. I started on a homebrew CNC machine years ago that is not running. And I need to complete some project before starting on another. Open source software that works smoothly seems to be a major issue for both projects. There is software, and it works, but learning 3D composition to generate the .STL files is still a bit of a learning curve for me! But it is coming, slowly, like everything I do it seems. :) I hope this helps!
May 17, 2007. 1:45 PMWeissensteinburg says:
I saw that yesterday, it's really neat.
May 16, 2007. 12:38 PMBrennn10 says:
I know, I think that time and money should be spent into making products of this nature.
Oct 20, 2007. 7:09 PMzachninme says:
I think the problem with this is that it is just innificient. Sure, it could re-make itself, but it'd be a ton easier having a piece of acrylic and just hitting it with a laser cutter :P It could make its own PCBs, that would be good. Maybe the belts -- if it can do with enough percision. I think that although this is a great concept -- a better one would be similar to what I outlined -- a fabber made from as much cut-out acrylic as possible.
May 14, 2007. 5:34 PMsam says:
I wouldn't say it very unknown, its been on the Make blog quite a bit..
Oct 20, 2007. 6:48 PMgr0k says:
I'm also pretty surprised that there isn't more stuff on Instructables about rapid prototyping. I've been following the reprap and fab@home projects, which look very interesting, but from what I've seen the quality is still too low to really get me excited enough to try it. I'm more interested in the inkjet technology used by zcorp. I've only found one diy project where someone is attempting to duplicate the zcorp process using the parts from an inkjet printer here.
Jun 15, 2007. 9:24 PMHonus says:
I've been keeping tabs on the RepRap and Fab@Home projects for awhile now. Both are really cool but I'm more interested in the RepRap as the idea of imbedding circuits really appeals to me- supposedly they're working on this in the next version (2.0 Mendel). I also really like the fact that it is open to all computer platforms- something that is seriously lacking in the home built CNC scene.
Jun 15, 2007. 3:48 PMcesar harada says:
hello guys, i'm sorry, i just understood what reprap is about a, n i found out that 2 of my projects i posted here are not at the right place ... the boat and the wallet ... the appartment maybe could be a kind of repap as it's made like a 3D printer ... Can the administrator of this group take out the 2 unfitting projects please ? Accept my apologies again. Cesar.
May 17, 2007. 12:34 PMBrennn10 says:
Same with me, but here is a link to the Fabber!
Fabber
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
