3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Revolutionary Pen Idea
This morning I had an idea. Last night I was dissassembling a huge bagful of insulin pumps (my cousin is a diabetic and he uses them, cleans them, and gives them to me to take the guts out of them) and in them I keep the springs, casing, and insulin resevoirs... (I ALWAYS throw those horrid needles away; I don't want to get stuck with one) I had an idea looking at the resevoirs... I wanted an ink pen that could write/draw in ANY color ink with the turn of a dial, adjustment of a slide, etc.. anyway, I have about fifty of these resevoir things (they have little pistons in them) and I was curious if there was a way to reach my goal. Should I use red, blue, yellow ink, or should I use magenta, cyan, and yallow? Do I have to make the inks myself, or could I drain them from printer cartriges? Should I use only primary colors, or secondary colors as well?
23 comments
Apr 12, 2009. 11:35 AMlemonie says:
Medtronic or Roche? These aren't the actual pumps, they're just the insulin refills? So you'd need some kind of drive for 'em? L
Apr 30, 2009. 3:30 PMlemonie says:
Hey, you could string all the batteries together for a high voltage DC supply! Rather than take these apart, I'd try to use the whole units (refilled with ink), you just need the control mechanism to activate the drive. L
Apr 12, 2009. 4:02 PMlemonie says:
You need motors? L
Apr 12, 2009. 11:40 PMlemonie says:
Ah well, good luck with it. L
Apr 15, 2009. 6:31 AMPKM says:
As I remember from my dad using them, you turn a dial to set the amount of fluid dispensed from the vial and then "click" the button on the end? I'm thinking of the injecty pen type, not sure that was what you meant by "pumps". In that case I guess you'd have the three (or four) ink reservoirs injecting into a central mixing reservoir, which then feeds the pen. To get a bit of orange ink you'd dial maybe 4 clicks of yellow and 2 clicks of magenta, or for lots of blue-black for writing you'd dial 10 clicks of black and 4 of blue. Then you'd click all the ink buttons you were using (after somehow "flushing" the pen reservoir, maybe just by scribbling or blotting) and write away. You can buy ink cartridge refills which come with four bottles of ink, or you can use food colouring if you don't mind water solubility. I don't know what sort of nib would be best though- probably a regular washable-ink fountain pen nib? gmjhowe is probably your man to ask about inks, but magenta, yellow, cyan and black are the usual printing "primaries" (you can make black from magenta, yellow and cyan but it doesn't come out great, black ink is better). Personally I think this is a great concept, I'm tempted to just get four of those small syringes and a fountain pen and play around.
Apr 13, 2009. 4:21 PMtechnoplastique says:
For an ink pen you can get drawing ink from art supply stores in lots of colors. If you want the cyan, magenta, yellow printer ink spectrum just go to somewhere like inkrepublic.com and buy refill ink. While you're at it, I highly recommend modifying your printer to run continuous ink, it's a lot cheaper than cartridges!
Apr 13, 2009. 2:24 PMwatermelonhead says:
awesome idea, hard to make. good luck.
Apr 12, 2009. 11:24 AMLithium Rain says:
:D I'm sorry, but that already exists! It's an awesome idea of course - it'd be neat to see how to make it yourself.
Apr 12, 2009. 4:25 PMLithium Rain says:
Ah, I see what you mean. Intriguing idea, I hope it comes to fruition.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
