SMD Soldering without Soldermask?
I'm working on a project and I needed to get a PCB made. I was planning on getting it from BatchPCB, but I ran into a little problem... I'm using a NAND Flash chip, which is TSSOP48; the footprint has 6mil spacing! (BatchPCB has a 8mil minimum) The next cheapest solution would be Barebones PCB, which makes prototype PCBs without soldermask & silkscreen. I'm worried about soldering on the Flash chip, and another LQFP48. Will the lack of a soldermask make it impossible to do?
1-10 of 14Next »
www.renaelectronics.com/picts/howto/stencil/movie_0001.wmv
you can manufacture a soldermask with this kit from renaelectronics.  It is a DIY kit that lets you etch thin metal plates... and it is cool.
westfw9 years ago
I find lack of soldermask a pain for SMT components. You are to some extent relying on the surface tension and adhesion of the solder to the pads to make up for impossible-to-hand-solder dimensions, and with no soldermask, the pads don't END...
yeah, but you don't NEED it, lol When possible it's nice, but many people do SMD soldering on homemade circuit boards I've only soldered on manufactured pcbs twice, and I will admit, it was NICE
zachninme (author)  guyfrom7up9 years ago
I'm just really worried about these package sizes. I've done [the SMT Atmega168's (I can't recall the size) on both homeade & "real" pcbs, and I could feel the difference. The NAND Flash chip has 6mils between pads. It was hard on a "real" pcb... I wanted to know if it would be significantly harder on something like this. And even the best homeade pcbs (that I've seen) don't go down to 6mil.
I would consider a soldermask an important part of a commercially made board, and that it would make soldering fine-pitch stuff significantly easier. I'm not arguing that it's POSSIBLE to solder SMT without the mask, but it would certainly be harder. You should be able to find a PCB maker that does 6mil clearance AND soldermask in their prototype service...
zachninme (author)  westfw9 years ago
Actually, I realized that AC's 33 each special w/ the student discount would end up being cheaper than their barebones service if I only get 1.
really, can you give me a link?
33each.com
LinuxH4x0r9 years ago
These are good for smd soldering
http://www.schmartboard.com/
zachninme (author)  LinuxH4x0r9 years ago
These are custom boards, that seems too expensive... I could probably get real prototype-quality boards for cheaper...
1-10 of 14Next »
