loading
Scaling of a windbelt - how small?
How small can a windbelt be made? I am hoping it is possible to make it at least 10cm
Kiteman9 years ago
The limit won't be size, but wind. Smaller belts will probably need much higher wind-speeds to start them vibrating.
PKM9 years ago
As small as you can make a tight strip of flexible material and a generator to capture power from it (assuming you want to generate power)- you can make a "windbelt" by putting a blade of grass between your thumbs and blowing :) The principle will probably work down to tiny constructions, although with household materials you are probably limited to a few centimetres long, but at that size the power and efficiency will be abysmal.
Why small? You could make them absolutely tiny...
