loading
Scanner inverter outputs
I've just been wondering about the output of scanner inverters for a few projects, what kind of voltages and amperages are they outputting. I have a few little ideas but don't really know that much about their outputs, I gave googling and parts numbers a go but mostly found unrelated pages or had no luck with part numbers...
1-10 of 13Next »
Big Bwana8 years ago
They output some where between 350 VAC to 800 VAC at around 5 to 6 mA some might be a little but higher but only by a mA or two and they are usally in the 30 to 50 kHz AC range... Some also have a much higher starting pulse in the area of 1200 to 1800 Volts .... What is the length of the tube it was powering ??
killerjackalope (author)  Big Bwana8 years ago
Eh the tube was broken, it was an inch wider than A4 paper... Almost ten inches...
About 500 to 600 V.A.C. at 5 mA.
Cool, thinking of things I can do with that now...
not much. its high frequency, low voltage. you cannot use a cwvm to raise the power. its not as good as a transistor setup for a flyback transformer and its not enough power for a plasma globe.
killerjackalope (author)  tech-king8 years ago
Hrmm It has one possible use but there's no way in hell I'm doing it yet, ya see electrolysis is better at low current, higher voltage, this thing runs off 12V already, got me a transformer for something now... But that is not an initial thing, that is strictly for later plans after initial experiments, which involve some lunacy as you know, also I hate to tell you this but all three bits are sitting on my desk ready to go, tomorrow we'll see just what will happen...
call me from the er lol.
I don't think I'll do the high voltage thing unless I somehow manage to counter the general problems that have stopped these things taking off, not likely...
what were the HV problems?
Nah not HV problems, more the whole system in general, they work to a certain degree but have problems...
1-10 of 13Next »
