loading
School Project: Gravity Car Design
Hey there guys... In my physics class we have a project in which we have to make a gravity-powered vehicle that will carry a given load along a track. The vehicle can only be powered by gravity (weights) and cannot use any other energy source such as elastics, springs, explosives, etc. I have started to make a K'nex vehicle but it is not very sturdy. The following is a picture of the rules and specifications. Much help is appreciated. Thanks
Fullsize Images:
Front Page
Back Page
Picture of School Project: Gravity Car Design
Aar000n3y9 years ago
For going up to 1,000 grams, I don't think KNex are strong enough... I think it would be better to just use a stronger material. Also, you should really use much bigger wheels (the ones that will be powered at least). Because one turn from a large wheel would make the car go farther than one turn with a smaller wheel.
RaDiKaL (author) 9 years ago
After 2 hours of work I have finally finished a prototype. I made it using K'Nex. I still have to add a smooth surface for the ramp on top (Any ideas of something light, smooth, and sturdy?). The very front wheel starts in a retracted position but when as the weight goes down the ramp the wheel lowers until it hits the ground giving it more support.
For a light smooth surface I recommend Masonite. it's very commonly available and very smooth. It may be too heavy though, and if worse comes to worse I would just use a thin cardboard or plastic.
RaDiKaL (author)  Firebert0109 years ago
Any ideas for a lube? :)
Um.. you shouldn't need one, but you could use graphite or talcum powder if you really wanted to. It would be super messy though lol.
Here's an idea: Why not make your device with a built in ramp. The rules don't say anything about prohibiting ramps, so it should be legal. You would have a large wheel that is held on the ramp by a string that you cut to initiate it. The weight would be suspended on a platform from the axle of the wheel, that way it would add to the momentum of the wheel as it moved. You could even go so far as encasing everything in a box (hiding the ramp from everyone) so that when you cut a string, the wheel pushes a side of the box down and goes rolling down the finish line. See the diagram if you don't understand.
I see what you mean and it is a very good idea but I THINK the whole thing has to move as one. The people would want to see what is inside the box i guess to make sure i do not have a pinball-like-launcher inside of it :). But if my Physics teacher says it is alright I will probably go with your idea.
guyfrom7up9 years ago
NEW INGENIOUS IDEA it's a 15 inch in diameter wheel the weight is the gray circle. there's a trap door under the weight. The door only opens one way (see position of hinge. The weight forces the wheel to turn, the weight remains on the bottom of the wheel as momentum causes it to continue. The load that you have to carry could either be located in the center of the wheel or next to the drive weight for more torque. the trap door is there for when the wheel makes one full revolution it'll just go through the dorr, not up and around the wheel, which is impossible and it'll stop the wheel. The arc is so you can start the weight at a higher position.
jtobako9 years ago
How about this-a weight pulls down on a lever (or string around a pulley), a string hooked onto the end of the lever/over the pulley goes down to a peg on the wheel axle (the rest of the string is wound around the axle). You'd have to figure out the best diameter for the axle, distance falling, amount of weight and type of tire (something with enough grip so that it doesn't just spin).
invent a gravity driven perpetual motion machine to drive the vehicle, win, and then trash the idea ;).
Use a giant lever, made out of alluminum or something, that pulls a string around the axel of the wheel, and use giant wheels, such as c-d's
our school does something similar, except it's with mouse traps (not fun when they close on your finger.
0 \
O
[] is weight
0 is pivot point for the lever.
\\\\ on the left is the bar for the lever
\\\\ on the right is the string
O is the wheel (attach the string to the axle
