Scrounging Electronic Components
Especially if you need a power transistor, MOSFET, voltage regulator, big capacitor, or reed relay which is not available locally. It just does not pay to mail order small numbers of parts, so having a grab bag assortment at home is handy.
But I have noticed that the some higher-quality PCBs just loaded with cool parts can be hard to scrounge from:
1. They are double-sided, or even multi-layered, with copper plating right through the holes (vias) so it is like pulling teeth, only harder.
2. They use no-lead (RoHS) solder which needs high temperatures to melt
3. They use surface-mount components and good luck removing and using those.
I use 15 watt, 40 watt, soldering irons, solder sucker, solder braid, flux, and a soldering gun. And for some items, a small windproof butane "jet engine" lighter as a mini torch to remove multi-pin items. Just heat-sink the legs and bang the hot PCB down to remove lots of solder at once. Of course I use gloves, safety goggles, ventilation, and proper recycling.
But the main issue is that it is getting harder to scrounge parts to build up a pile of useful stuff.
What resources do you use?
5
comments
Add Comment
Our local dollar stores sell 15 watt soldering irons for $1 USD, Maybe I could attach two of them to a spring-handled kitchen tongs (also $1 USD) and make my own Surface Mount iron.
I'd bend the end of the tongs, attach the irons with cable ties or hose clamps.
I could splice the wires so there would be just one plug.
I just now opened a $5 USD radio control truck to mod it, and nearly every capacitor, transistor, diode and resistor was surface mount. Only the radio coil and some power transistors for the motor control were through-hole.
![TWEEZERZD-409[1].jpg](http://img.instructables.com/files/deriv/FC9/I4AJ/GGPFCIWP/FC9I4AJGGPFCIWP.SMALL.jpg)
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
