loading
Sealed gravity liquid dispenser
I am looking to build a sealed gravity dispenser similar to this one.... http://www.dudeiwantthat.com/household/bar/liquor-log-booze-dispenser.asp I'm trying to figure out the best route to take, I have a beer tap I will be using. My problem arises with running plumbing in a solid piece of wood without cutting it in half. I plan to use pvc and but that means I need a 90 degree angle in the block of wood or log. Is it possible? My best idea is to drill my holes and cut a chunk out of the back that can be glued back. My next question is. How to attach a bottle? Obviously I have to have the bottle upright and place the dispenser on the bottle and flip it. But how to get a seal on the bottle that will work with different bourbon or whiskeys. Thanks on advance for any help.
jayanne5823 days ago
To attach the bottle take a one inch brass nipple and a regular coke bottle cap can be screwed on various bottles, not just coke bottles. In my case, it worked fine with Jack, Royal, and Hennessi.
What I did was I dremmelled a hole in a bottle cap, and screwed it into a fitting. Then a bottle can easily go into a fitting.
DavidH3455 months ago
I am wondering if you got this accomplished?
AndyB107 (author) 1 year ago
I like that idea... It set me in the right direction... I have already settled on 3/4 copper line. Little more expensive but it's what I found that worked for the spouts. Soldered a compression nut and pipe togther and used Water hose gasket to ensure a good seal (since I'm awful at soldering and the compress didn't seal).
My next step is as you suggested, open the bottom... But I plan to use a 90 degree shark bite fitting...
The problem still arises how to attach the bottle.
Kiteman1 year ago
Don't use rigid PVC, use a flexible hose.
> Drill down from the top of the block to make space for the bottle-neck.
> Drill in from the front to make space to fit the tap.
> Drill up from the bottom to make a cavity.
If you use a flexible hose, you can pull it up to connect to your bottle, then push it down into the cavity when you put the bottle in place. See my sketch - it's a cross-section from the side. The pale areas are drilled out, the black line is the route of the hose.
