loading
Security Certificate Expired
Has your security certificate expired?
I am using Internet explorer 8 on Windows 7 32bit.
Here are some pictures, because I suck at explaining things.
Screenshots are of where the webpage should go, and the address bar
edit: more pics
Picture of Security Certificate Expired
kelseymh5 years ago
You're using https to access Instructables? I don't think you should be doing that. In particular, the certificate which is supposed to be coming from I'bles is actually registered to an entirely different set of domains (see the fourth picture in your set).
On my machine (Firefox, MacOSX), the report is not that the certificate has expired, but rather that it is not valid at all:
www.instructables.com uses an invalid security certificate.
The certificate is only valid for the following names:
*.a.ssl.fastly.net , purge.fastly.net , fast.wistia.com
(Error code: ssl_error_bad_cert_domain)
skiedra5 years ago
Check your computer's time & date.
Sometime, if it's something like 2006 (dead on-board battery), and certificate start at 2010, browsers will give out an "invalid sertificate" errors
