loading
Short throw projector w/ auto pwr on/off
OK- looking to upgrade an exhibit that is currently using two old kodak slide projectors on an image blender to a screen that is only about 5' from the lenses. This is a rear projection scenario and I need the following criteria met: Projector must be capable of throwing up a 62" diagonal image from only about 5', maybe a few inches less. The projector must be able to be programmed to turn on (main and lamp power) and off at certain times. Whether this is done via the firmware (menu settings) in the projector itself or via RS232 commands is up to you but I don't know much about RS232 software and its capabilities as far as interfacing with a projector. I think there might be some projectors out there that automatically power on when a source is detected as well, perhaps this is part of a solution?? The application is as an exhibit in a museum. We can't afford to task someone with physically turning this on and off every day so if the process can be automated, great. This exhibit will ideally rear project an image to a screen that our visitors stand in front of. The image can be supplied by either a looping DVD or from a PC app such as Powerpoint as they are static images. One concern at power off is that power is initially only removed from the lamp of the projector and then from the fan after it has cooled the lamp sufficiently. If all power is removed from the projector at once, the fan will not run and the lamp will fail prematurely. If there are solutions outside of the box like other display technologies that I've not thought of, please share. Large plasma and / or LCD screens of that size however are cost prohibitive. Any help would be greatly appreciated. z
