3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Should be possible to edit comments
We should be able to edit comments that we have published. I found an error in a schematic I posted, for instance, and I should be able to go back and revise it instead of deleting the whole comment and re-posting. This is a common feature in other forum software.
25 comments
Feb 26, 2009. 8:47 PMegbertfitzwilly says:
Actually it seems to me it should be possible to trim comments or at least reorder them so that useful feedback for other readers doesn't get lost in meandering side paths.
Feb 16, 2009. 1:22 PMlemonie says:
Sort of Wikipaedia like? I just know people are going to get into arguments and then change what they said. It's a bit like teacher telling you to use a ruler and put a line through it instead of using Tippex (audit-trail, or is that just a neatness issue?) L
Feb 16, 2009. 2:51 PMlemonie says:
No. But I don't like the idea of saying something, having a redponse and then changing what you said. Because then the respondee has to go back and change their response. And it can go on... This could be abused by people, if it hasn't in the forums in which you've used it, I'd suggest that the community is different there. Imagine a situation where an answer is solicited, and then the question changed to put that answer in a completely different context. L
Feb 17, 2009. 11:28 AMlemonie says:
Well I'd like to correct "redponse" to "response", so I'm not at all against the option. I don't think it would be productive to discuss this much further, but having seen some lengthy exchanges, it helps to have a clear transcript of the dialogue. I made no claims of dysfunctionality (or did I go back and edit them out...?) L
Feb 16, 2009. 8:19 PMkelseymh says:
Sorry. I (just one user out of I'bles thousands) have already been in the middle of a discussion where one idiot made exactly that accusation against a member of the staff. Because comments _can't_ be modified post facto, not even by staff, several of us were able to point out said idiot's wrongness.
Feb 16, 2009. 6:28 PMLithium Rain says:
Oh, I can think of some bad ones. Lemonie has a good point. Users will abuse that feature. It can and will happen.
Feb 16, 2009. 12:56 PMlemonie says:
But then you'd get arguments about what people said and meant (and people can get into lengthy discussions...). Could you just reply to the original and point out the error? L
Feb 16, 2009. 1:28 PMKiteman says:
I think, ideally, that you should be able to edit posts that nobody has replied to. As soon as a reply is made, the post is locked, to prevent later edits causing problems.
Feb 16, 2009. 2:19 PMKiteman says:
In that case, I would say "no".
The temptation to edit posts to make replies wrong, or look silly, would be overwhelming for some posters, which could turn the forums into childish arguments.
So there.
Feb 17, 2009. 3:25 AMKiteman says:
Mainly because it's not something that needs much thought - if you pay attention to what you type, and read it through when you are done, your posts should not need editing.
If you need to change the way you have said something because of new information, or a change of heart or mind, then you should add that as a new post, later in the thread.
Feb 17, 2009. 6:52 AMKiteman says:
As GH said;
They are not non-existent problems, as I have a few sites institute this, and later become a hot bed of argumentation (I NEVER said that.....yes you did right......oh....you erased it ! I did not, you did too....). A lot of PHP boards allow this but the post is flagged with an edited flag. Still, I have seen a lot of abuse of it. One site, Care2, gives you about 2 minutes or so to edit your post, then it is locked.
Feb 16, 2009. 8:22 PMkelseymh says:
I don't think you're giving this very much thought. The hypothetical benefits do not in any sense outweigh the known and demonstrable problems. If you make a mistake in a comment, either delete it and repost, or create a new post (or/and followup to yourself) superseding the previous.
Feb 16, 2009. 5:00 PMGoodhart says:
Feb 17, 2009. 2:42 AMgmjhowe says:
I see what you mean. But really, most the time, if its a simple typo, it doesn't need to be corrected, as most people can work it out in their heads. It would be a nice idea, but not really needed on a site like this.
Feb 17, 2009. 1:23 AMNachoMahma says:
. No matter what you do, somebody will abuse it. IMNSHO, that's not a good reason to rule it (or anything else) out. . Considering the demographics of Ibles, would probably require a "Member In Good Standing" flag, that could be revoked if need be. . Since all posts are timestamped, I don't see where it is really necessary to be able to edit (although it would be a nice feature). If you make a mistake, post a comment with the correction. Not a perfect solution (comments can get separated by "subthreads"), but it works.
Feb 17, 2009. 2:18 AMll.13 says:
-Just a minor problem for us internationalers. ;)
I think if comments were allowed to be edited it should either be a) a one edit only, or 5 minute timeout.
Feb 16, 2009. 7:00 PMChicken2209 says:
I think so....
but one of two things need to happen
  • the post needs to be shown that it was edited. Maybe just an edited after the name or a different color font
or
  • The original post needs to be left unharmed while the edit just appears below the comment. EX:
i lkie pie
EDIT: I like pie
Feb 16, 2009. 8:39 PMn8man says:
I think that the corrrections should go like this.
Edit: Feb 16, 2009. 8:40 PM
corrections*
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
