Silicone or petroleum jelly for my rubiks cube
I need to lubricate my rubiks cube should i use petroleum jelly or silicone
Picture of Silicone or petroleum jelly for my rubiks cube
caitlinsdad8 years ago
I'm not sure but isn't there like a rubber band mechanism that holds it all together inside? I wouldn't know which one might have a reaction with the plastic used to make the cube. Maybe just try a dry lubricant like graphite or just dust it all with baby powder?
An oil based lube like petroleum jelly wears down rubber.
sk8master (author)  caitlinsdad8 years ago
thx 4 the suggestion
sk8master (author) 8 years ago
I used graphite to lube it. Just take the tip off a pencil use a paint scraper and grind it down on a piece of paper. Then you take the paper rollit up so it fits in the crevice you make by taking off one piece, and put it in and blows through the other end. Close it up, work it around and there you go.
lemonie8 years ago
It shouldn't need it - has it got grime in it or been taken apart? L
NachoMahma8 years ago
. Silicone grease works well and is compatible with most materials.
. Petroleum jelly also works. It is compatible with the original cubes*, but composition may have changed over the years.
. C'dad's graphite should work well, but I've never seen it used. Might get pretty messy.
  • It can mess with the sticker adhesive if you get carried away. Wipe off any excess. A little dab'll do ya.
