loading
Ski Helmet Walkie-Talkie Instructable Help
Hey, all! I'm new here at instructables. I'm majoring in Electronic Engineering Technology in college at the moment.
Anyways, I was reading through the (https://www.instructables.com/id/Build-a-Ski-Helmet-walkie-talkie-%22ACS%22/) Build a Ski Helmet Walkie-Talkie; and I have a couple of questions. I posted on the topic, however, no-one has posted on it in quite a while, so I figure I'd post here. Basically, I want to use this instructable to make an Airsoft headset (more than likely 2-way). Here was my comment:
"I know it's been a while since there was a comment, but I have a few questions. My friends and I play airsoft. I thought'd it'd be pretty neat if we bump-up the realism in the game with helmet (in my case a mask) to helmet communication. Now for the questions:
1. I may not be getting this, but how do you sync up the walkie talkie and the Xbox Live headset? I skimmed over your instructions, but have yet to try it.
2. Is it possible to have helmet-to-helmet communication? As in 1 Xbox headset to another Xbox headset, not to a radio. I would really only want just two headsets (for now, at least). I'm not really expecting this part to be possible with this current set-up, but any information you can give will be extremely helpful.
I'm currently majoring in Electronic Engineering Technology, so I have a slight idea of what I'm doing. I thought that this would not only be quite helpful and efficient, but also great practice for the field I'm going into.
Thank you for your time,
Darryn"
Any help on this project (and answering my questions) would be greatly appreciated!
Darryn.
PKM6 years ago
I assume an Xbox headset is a pair of headphones and a microphone with some kind of wired connector for each. If this is the case, many commercial walkie-talkies support external phones/mics so it's just a case of finding the appropriate connectors. If you're really lucky (eg. if they both use the semi-standard 4-contact 2.5mm or 3.5mm jack) they might just plug in and work. The Instructable seems to imply that the connectors are compatible but the XBox headset uses a non-standard arrangement of the contacts so might need rewiring internally.
AFAICT the XBox headsets are just headphones and microphones, so they can't communicate with eachother without something in between. This "something" is probably a pair of walkie-talkies.
caitlinsdad6 years ago
The ible was a hack on really any computer/gaming headset with microphone so it plugs into the corresponding inputs for mic, push to talk switch, and audio on whatever walkie talkie unit you have.
You may want to look up intercom circuits out there. You may be tethered together with wire so I don't see that as useful when running around. They do make helmet to helmet intercoms for two riders on the same motorcycle though. Good luck.
