Sleek/Small/Wooden Corner Wall Shelf
Hi there! I am no woodworker, but I do enjoy a DIY project here and there. I am wondering how hard it would be to make this corner shelf? It looks incredible, simple, sleek, and perfect for storing computer software and the like. I don't understand why they are selling it for 90 euros (120 USD). It seems simple enough to make.
Would it be possible to make this in good quality? If anyone is an avid woodworker and finds interest in this challenge, I would be very grateful if they would make a great Instructable on it.
Size: H 250mm, W 420mm, D 250mm
Material: Solid oak
Thanks very much!
Material: Solid oak
Thanks very much!
Fried Contest Launches 5/13, HQ Celebrates with Fried Day Friday
MEH! :D A Build Night at Montana Ethical Hackerspace!
Got contest ideas? Want to help HQ staff?
Large Instructables Robot head made out of driftwood, check it out!
Call for pre-made parts!
The Instructables Green Design Contest is starting on Earth Day!
My instructable made it into Popular Science!
Orbotix wants to see your hacks - you could win a Sphero!
Transformational experience for Instructables Artist-in-Residence
123D Design Vs. Rotary Tool. What is better?
Visit Our Store »
Go Pro Today »
one option (and maybe this is the case here) is to have a wall mounted metal frame which mounts securely and then this have a metal bracket which slides on to that. There may also be metal pegs coming out of a wall mounted which lock on (maybe what those two dark spots near the middle are).
I've had simple looking shelves which which worked like this.
Here's an example of the peg option: http://www.consmos.com/bracketless_wall_mounted_shelf_hollowboard.html
- get a 2 by 4 or other piece of wood
- cut two long pieces and two short pieces. These cuts need to be at a 45 degree angle. Each end of each piece should be cut in the opposite direction. For example if you imagined the end angles continued after the wood, they would come to a point (or form a triangle) on one side.
-Now you have two long and two short, glue them together like a box or picture frame (use wood glue and clamps)
-let it dry
-Now cut your box into two pieces at a 45 degree angle
-Flip one side around (should be easy to see how it goes now) and reglue.
On the serious note, wow -- that's exactly what I needed to help me visualize it. I do still have two minor issues, though:
First, I still am not confident about joining the corners. I'm getting the impression that even if I have the proper clamps(?) to do that part, I should still use dowels. It doesn't sound easy to align it all perfectly and make a clean joint with the dowels.
The other problem is the money issue of getting the tools and supplies, although I am realizing I don't need as much as I imagined. I would need to buy the wood (is it really just $2-3? I'd want something good quality...), the dowels, a corner clamp(?), I guess a miter box is what makes the 45 degree cuts, and then I have a hand saw and wood glue. Am I missing anything on the list?
Thanks very much for your help!
You guys are starting to convince me to give this a go myself...
I'm not a pro woodworker, but I build things often. Since you are new I would say to skip the fancy ways to do the edges and start simple. As for clamps, you do need to clamp wood, but if you don't have the cash you should be able to keep pressure on for the glue. I just made a bunch of picture frames and to glue them I used a metal square box and two heavy weight lifting weights to hold the joint tight. Clamps are easier but you can figure out another way.
You can also do without a miter box, although it's also probably cheap and worth it (but everything adds up). Draw good lines for your angles and cut just a bit outside. Use (and buy) some sandpaper (medium grain probably) to get the edges nice. [since your new i'll mention that you wrap the sandpaper around a scrap wood piece to have a flat sanding edge].
Really the best thing you could do would be to find some scrap wood and try stuff first. If no scrap is around just buy something smaller and cheaper to try first so you can see how it will all work. Something like http://www.homedepot.com/Lumber-Composites/h_d1/N-25ecodZ5yc1vZbqpg/R-100075477/h_d2/ProductDisplay?catalogId=10053&langId=-1&keyword=wood&storeId=10051
At only 75 cents for 8 feet (it's much narrower) you can try cutting and gluing and all that out first. I'm sure hand sawing through 2 by 4's will not be pleasant, especially if you make a mistake and need to redo things. So just make a mini version first and the final shelf will likely come out much better since you'll know what works.
You could mount it with L-brackets to studs, and it would hang fine. I kind of want to do this...
Anyone?
Good luck, pal!
This is pretty much 2 or 3 bucks worth of 2 by 4 and a few simple cuts. And for $120 a piece you would have profit margins which would put drug dealers to shame.
I do hope someone tackles this. :D
I thought so too. In addition to that corner, I'm trying to figure out what we would start with... a big block of wood? And those dimensions don't exactly make sense to me.
Thanks, I hope so as well. :)
It helps to have a chop/miter saw but a handsaw with a miter box helps.
The top L-shape and a side is cut from one half of your stock.
Cut a 45 degree angle across the face and flip one piece over to get the L-shape. Cut the 45 degree miter joint for the corners by cutting across the thin edge. Flip that piece to make up an L-shaped corner. The other miter cuts have to be planned accordingly.
There are many ways to join the corners and strengthen up the joints. Glue and dowels, pocket hole screws, traditional joinery, etc. You would also need to mount it to the wall with additional brackets or I would just put pocket holes where you find the studs in the wall. You can fill in pocket holes with pegs or wood filler. You will rarely find a true square corner due to the finish of a wall so your perfect shelf corner may not fit so well and you can scribe/sand to fit. Good luck.
If you do the single-miter-and-flip trick five times, leaving just the two ends to be notched off, you can probably build the whole shelf with less than a five foot length.
I would actually want to make it a bit taller and wider, now that you mention it. It looks great at its current size, but I would personally use it as a shelf for my software boxes.
I am very limited in the tools area, unfortunately. I think I'm most concerned with joining the corners well. I don't understand how dowels would do that, but would clamps work? I really like the idea of hanging it with dowels, though.
If you're limited in the tools area, and don't want to spend a lot of money (not knowing if you're going to continue doing woodworking projects), it is possible to rent the tools you need. Some of the big box stores (Home Despot, etc.) have that service available. You would need either a miter box and good quality hand saw, or a chop saw (circular saw mounted on a stand).
If you enjoy working on a relatively simple project like this, then you should consider investing in (or asking as presents!) good quality tools.
Oh, I didn't know I could rent tools, nice. I may have to go with that. I don't have money to spend on buying them, really, but I might go ahead and throw a few on my wishlist. Thanks for all the help!
On another note, I still do hope someone will put together a good instructable for this. Heck, I'll give it a go if I decide to try to make it, but I'm not nearly as experienced as other woodworkers here.
The "official" method is called biscuit joinery, where you cut a slot in both sides of the miter, and insert a thin, oval-shaped wafer of wood (the "biscuit"). This requires a special tool called a biscuit cutter to make the slots for you; that's probably why Caitlinsdad recommended dowels instead.
Thanks again, I'm learning something new with every comment.
