loading
Smoke bombs that explode on contact - version II
my idea is as follows
have an outer layer
inside that you have small glass capsules which will break and ignite the negative-X
then another very very thin shell
then the inner core of a regular sugar & potassium nitrate smoke bomb
the way it works is the bomb will hit the ground causing the the glass around the water to breake causing the negative-X to react then that ignites the smoke bomb which will make smoke billow out a designated hole
ps. if you want to know how to make these things go to
http://www.unitednuclear.com/negx.htm for Negative-X
https://www.instructables.com/id/E6F4H9Z605EP2867LO/?ALLSTEPSfor the smoke bomb
Picture of Smoke bombs that explode on contact - version II
1-10 of 29Next »
batonas5 years ago
cut tenis ball in half cover inside of the ball with match box stikeing thing (dont know how its called) cover it with match heads add smokemix in the middle, now throw it to a wall and see if it works, throw hard
P.S. best smoke mix I know 10 citric acid ( flavoring, white crystals) and 15 parts of potasium nitrate. make it like sugar one, add few drops of water till moist then cook on low heat and stir. it will not burn, but quickly smudge just perfect for, altough not the cheapest. hope I helped. someone can make instructable out of this I dont care, but let me know if you would like to.
Lextone10 years ago
I actually have a recipe somewhere to make "torpedoes". Small round balls that will explode when thrown at the ground. By altering the mix you can make a cloud of smoke, a shower of stars or even a very bright flash and loud boom (lightning torpedoes). Problem is, they are very unstable, they are not easily carried in a pocket for the Ninja warrior get away . They may make your fingers...and maybe a leg....and an eye or two.... not to mention your hair...magically disappear They are dangerous to make, dangerous to store, dangerous use, and in all states they are classified as a high explosive and therefore illegal. Some of the ingredients are no longer readily available, so you better be ready to do some chemistry work to make your own. There are plenty of recipes for smoke bombs out there that actually work better than what you are imagining. So go mess with those and devise a impact fuse to light one of them off. And before you ask.....NO you cant have the recipe!
Impact Firecrackers
The above link is what Lextone was referring to.
A layer of Torpedo type composition over a base smoke filler is clearly the answer. The original suggestion of this thread is far to mechanical.
I WOULDN'T GO TO THIS PAGE ANYMORE!!!!! now that I have your attention, the above link is deemed by trend micro "dangerous". It says that there is malicious hardware on that site. Cracker(original1) I don't know whether this was intentional or not, but if it was, you should be ashamed, if not then you should be happy I caught this before who knows how many people died a horrible virtual death. I do not expect that you did this, it probably wasn't there 4 years ago, and if I have insulted you in any way, I apologize now, it was not intentionable.
Trend Micro is probably just giving a false positive here. These sites should be fine.
Depending on the inside layer "base smoke filler" composition it could be made to "go" very fast such as a Nitrocellulose binded Flash compostion, with smoke additive (use large grain Aluminum Powder) or slow like a Ammonium Chloride-50 parts Potassium Chlorate-35 parts, and Lactose 15 Parts <(Professional recipe)Composition will provide. For the Ignition slurry I would experiment with a Nitrocellulose binded version of the coating they use below>
When a super thick slurry is made using two much NC Lacquer it burns instead of bangs (Experimentation will be completly nessacarry to achieve proper results)
Crack Balls
I like to try to figure out how commercial fireworks products are made. Here’s a case in point. I found these two little colored balls, which, when hit together, make a bang. You would think that if you coat a stone with something that will detonate or burn it would cause a chain reaction and burn all the way around, but it doesn't if you do it using the formula below.
and Remember always be cool and NOT "Kewl" got it :)
Crack Ball Formula
Ingredient Parts by Weight
Potassium chlorate 60%
Sulfur 35%
Dextrin 2%
Powdered glass 3%
The formula will work without the glass, but not as well. The glass helps it to detonate. I had some glass beads from a bead blaster. I used my mortar and pestle to ground it into a fine powder. You could do the same with broken Christmas tree ornaments or any other thin glass using a cheap coffee and spice grinder from Wal-Mart.
I screen the sulfur, dextrin, and glass together, mixing thoroughly.
Never screen chlorate with sulfur. Always use a different screen for the chlorate!
Then I screen the potassium chlorate separately, using a different screen, used only for the chlorate. Do not mix this with the previous ingredients. Keep it separate. Make sure it is reduced to a very fine powder, getting rid of any lumps.
First mix all the ingredients EXCEPT the potassium chlorate together with enough distilled water to create a slurry. It should be thick, but still runny, about the consistency of Elmer’s Glue. Then stir in the potassium chlorate. If the mix becomes too thick, add a little more water. Add food coloring if you want. Then get one of your kid’s paint brushes and paint it on a smooth round stone that you can find at your local creek. Be sure the stone is fairly round, definitely not flat. If you don’t want to paint the rock, you can dip the rock in the slurry. Let dry very well. If you are as impatient as I am, you could use a fan to speed things up a little. These things have to be very dry before you use them.
Honestly, the mixture of the potassium chlorate with sulfur seems to dangerous for any use, even in water. Heck, I wouldn't recommend using potassium chlorate in ANY circumstance due to it having the potential to ignite from contact with so many things, including a screen if metal (!). But chlorate with sulfur is a big, big no no. Seriously, it could explode from anything. The very act of putting it into water could make it explode. I know for a fact the simple act of putting a spoon into a KCl mixture can cause ignition.
I am sure cracker(original1) you know of the risk of the mixture, but for others the risk of chlorates and sulfur is dangerous even for pyrotechnics. As a curious observer, would potassium perchlorate (which is much, much safer) work as a substitute or would it be too stable then?
Hmmm...Good question. Some experimentation is in order. I would say it would be more stable, but with a delayed ignition. Like a strike anywhere match. Lex
mr j124 Lextone7 years ago
plz can i have the recipe i need a good recipe i have one but did not turn out so good i blew a hole in my cement padeo it was awesome for the most part
master-of-chaos (author)  Lextone9 years ago
check out the contest then at here
1-10 of 29Next »
