loading
Solar USB, iPhone, Arduino Chargers
I write up a lot of guides on Instructables for various solar gadgets.  Most of the Solar USB/ iPhone/ Arduino chargers.  If anyone is interested in such things I sell them off my website, which I then use to make more projects or fund activities in my science classroom.  I have several versions of my kits available as well as all the parts to make those kits, and even premade chargers for those who don't feel the urge to make one on their own.
A basic USB charger that uses rechargeable 2 AA batteries, a DC to DC boosting circuit, and a 4V solar cell.  Take the batteries out to charge, or leave it in the sun for a few days.  Then charge up your gadget when need be.  Works with most USB devices including Apple products (iPods, iPhones, iPads) as well as Arduinos.  Fits nicely into an Altoids tin.
More or less the same as the USB charger, but instead of having a generic USB port it has a dedicated iPhone/ iPod/ iPad cable.  Which means it only works with Apple stuff.  Features 2 rechargeable AA batteries, boosting circuit, Apple Connecting Cable, and 4V solar cell.
While the 4V solar cell in the other kits/ chargers fits nicely inside an Altoids in it is also quite wimpy.  I took the basic design of the Solar USB Charger and replaced the 4V solar cell with either a powerful 6V 230mA or a 5.5v 320mA solar cell.  In order to make things easier the solar cells plug into a 2.5mm jack on the side of the tin.  Meaning you can leave the solar cell at home.  The solar cells are also powerful enough to charge up a lot of gadgets directly from the sun if you have good weather.  Works with most USB gadgets, Arduinos, and Apple products.
Due to the fact that big gadgets (like iPads) have insanely big internal batteries I had to modify my design a bit.  The AAs in the other chargers were not powerful enough (unless you used 4 or 6 of them) to reliably charge up bigger items.  I modified the design of the Heavy Duty Kit to replace the AAs with a Lithium battery and Charge Controller.  With several battery options available, including a massive 6,600mAh one, these chargers have no problem handling the larger power needs.  On a recent plane flight a charger with a 2,000mAh Lithium battery charged up my iPhone over 80% (on airplane mode while listening to music).  Imagine what a 4400mAh or 6600mAh battery could do.  The charger/ kit can fit inside an Altoids in with the smaller batteries.  It features a powerful 5.5V 320mA solar cell and a 2.5mm jack and plug system so you can easily remove the panel.  A nice addition is the Lithium Charge Controller which has status LEDs showing when the battery is charging and when it's full.  It works with most USB gadgets, including Arduinos and Apple gear.
I've used these kits with kids at my middle school, and have sold many kits to summer camps and scout groups.  They take between 20 and 45 minutes to make, and only require basic soldering skills to put together.  They all fit inside Altoids tin for cuteness factor, but can easily be put into something else.  Modifications are endless.
So there you have it.  More Altoids solar thingys than you can shake a stick at.
szaffarano12 years ago
I am working on a community project restoring a city park and we're putting an old car in as part of the decor. What I would like to do is to place 1 or 2 solar panels into the grill of the car (it will be facing up and in perfect alignment to catch the most sun w/o osbtruction) that will power the 'headlights', neon glow stip, and possibly a phone recharging station. Can you give me an idea of what kind of lights I should use (to shine up into the sky), and the size of the battery needed to fulfill that kind of power requirement? I'm thinking large LED's (using the same mirrored backing as the internal compartment of a head light), and a single colored strip of neon or even LED chain lights. We'll have 80% of the volume of the vehicle for placement of batteries, control board, etc. Thanks for any advice! Steve Z.
ckgarside4 years ago
Do you have a charger capable of charging my Nexus 7?
simply.alon4 years ago
I believe I'm in love with your kits! Checking out your site in a jiffy. Thank you for sharing!
binoyxj4 years ago
Awesome kits. Thanks for sharing :)
BrownDogGadgets (author)  binoyxj4 years ago
No, thank you and everyone else who keep buying them. Solar gadgets are easy to make, inexpensive, and completely fun. I think everyone should give it a try at some point.
