Solar operated timer - NEED Help Please...
I need help!
I have an idea of a product I'm designing to get accepted to a design school.
I need help since I have very little knowledge in electronics.
I need a circuit for a timer... an egg timer with a twist (I think)
Should have a switch (click type), 1 Buzzer, 6 indicator LEDs, and I take it that some kind of Controller (I have no idea what kind) and should work with solar power.
Should work as follows:
You press the switch once - one LED is lit and the timer count back 10min. and then the buzzer will go off. press it twice - 2 LEDs are lit and it will count back 20min till the buzzer goes off... and so on up to 60min.
If 6 LEDs are too much for Solar power, 3 are also OK (30 min timer) or NO LEDs, but a "beep" indication for each press / 10min. time.
I hope it's possible
And thank you all for your HELP!!!
Take a look at the attached picture... Just to get a laugh
ET
4
comments
Add Comment
http://www.bek.no/~flemming/flemmweb_current/schem/CMOS/4017_circuits.pdf
http://www.bek.no/~flemming/flemmweb_current/schem/555/555_howto.pdf
http://www.bek.no/~flemming/flemmweb_current/resources.html
I hope this is helpful, I am planning to build something similar to this, to use as a timer. Good Luck
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
