Someone help! DIY wah wah guitar effect
17
comments
Add Comment
Regarding Wah pedal circuits: The standard wah is usually a variation on the classic Vox Clyde McCoy pedal. The circuit itself isn't very complicated, but read on...
There are problems with DIY wah pedals, especially if you're building completely from scratch (and don't want to spend much):
-- The pedal itself is difficult to fabricate (most DIYers buy a used, non-working pedal to start with.)
-- The POT used in wahs is usually a custom taper, and almost always a sealed POT. Translation: expect to pay $20-30 just for the POT. If you're starting with a broken pedal, its POT might be usable...
-- The classic design requires an inductor, value of approx 500mH (milliHenries.) Common types are Fasel and Halo. One of these will cost $15-$30. There are alternatives: such as using a small audio output transformer for the inductor. See this article for details (it's got more info than you need.)
The upshot is that wah pedals are more an intermediate project, simply because of the cost and fabrication skills needed... compared to a simple fuzz or booster, anyway.
RE: the pedal itself-- search ebay for something like "wah repair" or "wah project".
There's another option, too: the expression pedal from an organ. Although they don't have nice enclosures like guitar pedals, they should have both a working pedal and a sealed POT. Try searching ebay for "organ pedal" (I see one now available for a total of $16, although it ends in only two hours...)
For an inductor, google or search ebay for "wah inductor", plenty should show up... The "tech" link I posted above has some other inductor ideas...read the Building a Wah from Scratch section.
He also mentions some inductor-less wah circuits, but the classic type that use an LCR filter (L = inductance, C = capacitance, R = resistance) requires an inductor in the circuit... They are the most popular for a reason: inductor exhibit resonance, which is why wah-wahs sound like the do...
Inductor-less wahs aren't very common because they don't sound as good (personal opinion, shared by many)...but they do sound different from most wahs, so the occasional commercial version is available.
Something like the "multi-face" or the "Sili-face" on runoffgroove, both based on the "fuzz-face" (60s fuzzbox.)
Or Craig Anderton's Tube Sound Fuzz (I built one years ago and it sounds cool.) Here's a nice PDF with diagrams and schematic. This design uses a CMOS 4049 hex inverter chip for the guts--it's easy to find online.
http://www.generalguitargadgets.com/index.php?option=com_content&task=section&id=6&Itemid=26
Can't say what the easiest one would be though.
Probably the simplest project on there would be the Little Gem amp, or something like that. Alternatively, the Tone Burner Fuzz doesn't seem like it would be too difficult, just a larger number of parts.
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
