Square Brackets in Back Talk
6
comments
Add Comment
For Example - This Project I added [ and 93. In viewing the project, it will not show square brackets. BUT, in the backtalk page, it looks for markup and applies.
Are you working for instructables? If yes, let me know that you saw this so I can restore the original formatting.
Also, I noticed the new code doesn't like links that ref. Archive.org
See Two Links in this Step. Both of those urls work, but I don't know what the site is looking for when it checks for a valid address...
I like using arichive.org in places where I feel the linked site will go down in long term....
Thanks
It appears to me that (surprisingly enough) I'bles is handling the literal square brakets correctly. If you are seeing something else, it would really help Rachel if you took a screen shot and appended it to the forum topic.
Now, if you go back and edit those I'bles, does the title come back for you with the literals still embedded? Or have they been changed to explicit bracket characters, and you then have to re-replace them with the entities again?
You're very right about problems with where markup (especially entities) is interpreted vs. literal. Basically, the comment fragments shown on your backtalk page have the markup codes stripped out or otherwise mangled. Just ignore them. If you follow the comment link, the formatting should be correct.
As for the "archive.org", it looks like that site is embedding a redirection in its own URL. I am not convinced that that is actually valid under the HTML specification (I would need to re-read it). Why don't you try avoiding the redirection and just provide direct links to the destination (i.e., strip everything prior to the second "http:").
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
