COMMUNITY : FORUMS : RIDE
Stair Ride
I had an idea about making going downstairs fun. You grab two handles, which are connected to a frame on the ceiling. As you move/fly downstairs, the handles scroll along the frame quickly, thus making the simple process of going downstairs fun. :) Absurd or do-able? Does anyone know how to make such a thing?
verence says: Jul 18, 2012. 8:38 AM
Question: How do you bring the handles/grips back to the top?
canucksgirl says: Jul 18, 2012. 5:29 PM
Persuasion?
Goodhart says: Jul 18, 2012. 5:17 PM
motor?
lemonie says: Jul 18, 2012. 12:26 PM
Elastic...?
L
canucksgirl says: Jul 18, 2012. 4:08 AM
Sounds like you're suggesting a "zip-line" for going down a set of stairs?... While I think the idea (in theory) would be kind of fun, I'm not sure how practical it is. Most staircases are rather short (with some building design exceptions of course), so it wouldn't be much of a ride if it ended just as fast as it started.
If you're still into this idea, look at the design of a basic zip-line, as I would think a cable system would be easier and less expensive than ripping a ceiling apart in order to fashion some other method.
And if you do make such a thing, you must publish an Instructable. :-)
mh76dk says: Jul 18, 2012. 5:08 AM
Also make *explicitive* sure this is fastened and can carry more weight than just your own... i can say from experience that falling down a flight of stairs is not fun (though i have done it without the need for fancy setups :)
canucksgirl says: Jul 18, 2012. 5:29 AM
I didn't find the "falling down a flight of stairs" ride very fun either... :-|
caitlinsdad says: Jul 18, 2012. 3:13 PM
I didn't find the "getting pushed out of an airplane and falling very fast" ride very fun either...those guys and gals in the military are a fun lot.
canucksgirl says: Jul 18, 2012. 3:57 PM
I could handle that ride. With mine, I think I was missing the parachute. The landing was a bit hard. :-|
well, with such a short fall, a parachute would have been of little use ;-)
mh76dk says: Jul 18, 2012. 5:21 AM
I also found this http://dangerouslyfun.com/zip-line which will show you the basics of an (outdoor) zip-line. notice the comments regarding the dangers.
mh76dk says: Jul 18, 2012. 5:15 AM
One way wuld be to fasten a rail to the ceiling and (a C-shaped with the open end downwards - like used in garagedoors and ports) you can then use a (rubber)wheel of sorts and given a little friction (i am not sure a free run is all that fun - might depend on how far a ride you make) it might work
(totally pulled out the opposite side of my front, though i have in my younger days worked in a place that produced the mentioned C-shaped rails and packaged it with wheels/brackets for garagedoors, ports)
But as mentioned, SAFETY, this has the potential to cause a lot of damage to the user or the one getting hit at the bottom (im such a party-pooper)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
