3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Standardized Electronic Components?
Hello all, I was just wondering about finding electronic components. Some parts, like resistors and capacitors, seem pretty easy to sort out as long as you aren't looking for something out of the ordinary, just find the values you need rated for the wattage, etc. However, in the case of transistors and things like that, I am always seeing many different numbers (people say "a such-and-such transistor, like a {serial number}". Is there some general standardization for these parts? Or at least, some nearly universal sourcing that is considered a "standard"? I only wonder because trying to find components can be a real pain. I have a transistor, I know it's an NPN Darlington transistor, but that's about it. Others that I have salvaged I don't even know that much about. Any explanation or links to sites that explain these things would be much appreciated. Thanks in advance for any help!
9 comments
Jan 17, 2009. 1:02 PM11010010110 says:
some names have a story behind them. for example a 555 is named after a 3 series 5 K resistors inside it some names are made to be related to others. for example 2N3055 is a high power npn txistor and ME2955 is the PNP txistor designed to be used together with 2N3055 some components include one of their parameters in the name. for example 7805 7824 are constant volt supply chips for 5 and 24 V. 80523P333512 and 80523PY400512 are intel pentium 2 processors with 333 / 400 mhz and 512 k cache other components have just random names if you want you can build a list of components you use often and their specs
Jan 17, 2009. 2:23 PM11010010110 says:
i know by mind some substitutes for the most common tasks
for example C945 (and H945 etc) is my duct tape small npn txistor for allmost everything. it can be found in huge amounts in allmost any crt monitor or computer power supply in the trash. no need to buy
Jan 17, 2009. 11:20 AMNachoMahma says:
. If you have the "part number," just type it into Google (or your favorite search engine. Eg, to find info on a 2N414 transistor, just Google 2N414.
Jan 17, 2009. 1:56 PMNachoMahma says:
. Request a copy of the "NTE Semiconductor Technical Guide and Cross Reference" from NTE Electronics. It should have most of the info you need. They also have an online parts cross-reference.
Jan 17, 2009. 12:10 PMguyfrom7up says:
well, probably not very helpful, but in the begining (like 2N3904) means how many pins the device has minus one. Like diodes (2 pins) are 1n and transistors (3 pins) are 2n
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
