loading
Stupid Question: (soldering iron) = (woodburning iron)
I have a woodburner and I was wondering if I could use it as a soldering iron? Is it just getting hot enough to melt the solder that I have to worry about or is there some kind of load problem with using a woodburner for this purpose? need help!! (obviously)
1-10 of 16Next »
ADRIANT283 months ago
It should work however I would suggest not to use the most expensive soldering iron. Also I suggest using a tip that you have cleaned free of solder. Also I suggest not using the same tip for soldering as the tip is no longer clean.
iman9 years ago
there are no stupid questions just inquisitive idiots :) lol just kidding, my soldering iron has a wood burning tip too.
sk8erdude9 years ago
would the tip of a hot glue gun work???
Goodhart9 years ago
I found something out. I believe the "tips" are a bit different. If you don't mind having the tips wear away faster then they normally would with a regular soldering iron, you could use the wood burning tips. I wouldn't switch back and forth though, a "tinned" tip will just add lead to your wood burning :-)
NachoMahma9 years ago
. According to Wikipedia," Lead-based solder uses 250°C to 280°C or 300°C while lead-free soldering needs a higher temperature, about 350°C to 400°C.". Googling woodburning pen temperature tells me 25W woodburners run at about 900°F (~500°C).
. What that means, as far as your question, I dunno.
Goodhart9 years ago
Two things, both have been mentioned here, so I will condense: #1: do the tips fit (threads) ? If they do, move to step two #2: are the irons close in Wattage. If yes to one and two, we are in business. If the wood burning iron is a starter 5-8 watt jobbie, you may have trouble melting solder with that. If going the other way, and you try to use a 30-50 watt iron to burn wood, expect a lot of smoke, and a lot of black patches. I think all my irons are around 15 w, except this one monster job I got at a flea market....looks more like an old policeman's club than an iron, and is great for "big" jobs, but not for IC's or such.
Oh, I forgot to add, most of my soldering irons don't have threaded tips (my desoldering iron does).
bardon08 (author) 9 years ago
Here is a scan of the tips I now have. which one would work best? I looked at the actual iron and the wattage is 23 at 120 VAC.
C:\Documents and Settings\Karen\Desktop\woodburner tips.jpg
. The temperature of the tip is the important part. Too cold and it will take too long to melt the solder, allowing heat to build up in the part. Too hot and you're liable to burn up the part or destroy the traces/pads. . The best way I know to find out is to try soldering some junk parts and see what happens.
KentsOkay9 years ago
Can you change your tip? If so yes.
1-10 of 16Next »
