Sucking Carbon out of the air?
21
comments
Add Comment
and why use lye, when you can plant a tree? (which is self-sustaining and removes carbon for decades.) Or grassland, or your favorite crop..
If "organizations" are using tubs of lye, and not at least converting to limestone which gets buried somewhere safe, well congratulations, the "environ-mental nut-job" label has been earned again.
Which would work until someone decides too much energy is being wasted by using huge vats, the foul governments and multi-national corporations can't be trusted, nature is always best, and dumps some of the organisms into the ocean where they freely multiply.
Does anybody here need the play-by-play of what happens next?
Lye and similar compounds are well known carbon dioxide absorbents. They're used on submarines and space craft and oxygen rebreathing apparatus and such.
If you're going to put out huge tubs of lye to "solve" the problem, they'd better be REALLY huge. As a rough guess, every ton of fossil fuel burned needs at least THREE tons of lye to absorb the CO2 (for your chemistry homework, produce a more exact number :-)
Of course, CO2 has a global average concentration of 0.0387% by volume, so that's a lot of air to circulate to remove carbon. This works better as an industrial scrubber for power plants, etc. And as soon as you can get the good decent citizens to accept many tankers of lye on the highways and railroad tracks thru their neighborhoods on the way to those industrial sites, then it might work.
Regarding the carbon fibre, westfw didn't mean to have it loose, like glass-fibre insulation, but embedded in a resin as a composite material.
If you could coax a plant to grow carbon fibres internally, and to excrete a UV-stable resin instead of the lignin, you could produce huge amounts of carbon-fibre composite sheeting in adapted paper-mills.
(That was another joke, by the way)
Here's a "field report" from a supplier of knifemaking materials:
Some of the advantages of carbon fiber sheet are high strength, light weight, dimensional stability and corrosion resistance.
The disadvantages are tooling wear and health concerns. Carbon fiber dust is VERY VERY BAD FOR YOU. Always wear a respirator when working with carbon fiber. Keep the respirator on when cleaning your work area. Do everything possible to avoid breathing the dust. The dust will make your skin itch. Every time we work with carbon fiber we spend the next few weeks digging little black splinters from our hands. I keep saying that when our current inventory is gone we will not sell it again. I truely hate working with this material.
Oh, and replace lignin? It's such an integral part of a plant's structures I doubt we could genetically engineer a replacement, especially something as specific as a UV-stable resin. Besides, paper mills are not known for making products with aligned strands, and a random-orientation paper-thin material doesn't seem to be useful, given that current composites derive much of their strength from using a long-fiber fabric. Especially since once the resin cures it'll probably be too stiff to roll up as is done with paper, really will just be a brittle sheet that'll fracture easily, releasing those annoying little fibers. But it might burn well, there's likely a need out there for weather-resistant emergency tinder.
(Strange, never had any problems picking up on British humor before, enjoy everything from Red Dwarf to Waiting for God. Maybe it's one of those things where something so small gets easily overlooked...)
Carry on people, nothing to see here...
...otherwise known as kindling.
On a positive note, if one put the coke behind steel walls, one could stay warm most of the winter, by igniting the coke and not leaning against the steel walls LOL They CO and CO2 might be a problem though....
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
