[TUT] Setup a VPN on an Xbox 360 and Xbox one Console
Info:
There are many benefits to routing your xbox IP through a VPN connection. This ranges from utilizing exclusive American content, to hiding your IP from DDoSers, or even hiding your location from Doxers. This tutorial will show you a loophole that allows you to get around/avoid these hassles. Let us begin.
Things you need:
WiFi Connection
Laptop with LAN port
VPN (Virtual Private Network)
Ethernet Cable
VPN's:
IPVanish
PureVPN
ExpressVPN
This tutorial was done using IPVanish When installing these, make sure it sets you up with an American IP so you have access to American Xbox Content.
How to Setup VPN on your Xbox Console
Use Router Base Connection to Setup VPN on Xbox
One of the methods of setting up Xbox One VPN is by tunneling your service via router and then connecting your gaming console and other devices to the router. Note that the setup may vary according to the router you use and the instructions provided by the VPN provider.
Use the following steps to configure a VPN service on your router:
You need an Ethernet cable and connect your modem to the WAN port in the router.
Open your Router’s Control Panel – accessible from your system control panel.
Go to the ‘Basic Setup’ / ‘Network’ / ‘Basic’ tab in your router control panel (where you can configure WAN or Internet settings).
Enter the setup details provided by your VPN provider (username, password, gateway, subnet mask, etc.).
Select the appropriate protocol settings and the change the ‘Connection Type’ based on your router and VPN providers instructions (usually to PPTP, but it depends).
Select the appropriate DCHP settings depending on the requirements by your VPN provider.
Click the Apply Settings / Save / Connect button and you are done.
Now you can connect your Xbox to the router either through Wi-Fi or through Ethernet cable and can enjoy using VPN on your Xbox 360 or Xbox One.
Use Your Computer to Setup VPN on Xbox
You can also configure a VPN service on your Xbox through sharing the VPN connection on your personal computer with the gaming console.
Firstly, setup a VPN connection on your computer:
Go to ‘Network and Sharing Center’ from your system’s Control Panel.
Click on ‘Setup a New Connection or Network’ and a wizard will appear.
Select ‘Connect to a Workplace’ and click ‘Next’.
The wizard will ask ‘how do you want to connect?’- select ‘Use my Internet Connection (VPN)’.
Next you will have to enter the Internet Address and Destination Name provided by your VPN provider. Enter the details and click ‘Next’.
Now enter the Username and Password of your VPN service and click ‘Connect’.
If you already have a VPN configured on your computer, use the following steps to connect it to your Xbox:
Connect your Xbox with your PC using an Ethernet cable or Wi-Fi.
Go to ‘Network and Sharing Center’ from your system’s control panel.
Click on the ‘Change Adapter Settings’ on the left side bar.
Right click on your VPN connection and click ‘Properties’.
Go to the ‘Sharing’ tab and check ‘Allow other network users to connect through this computer’s internet connection’ option.
Click on the drop down menu below ‘Home Networking Connection’ and select ‘Local Area Network’. Click ‘Ok’.
Get an Rpi and set up your own.
Better suited as an instructable rather than a forum post.
